MyQL join error
Dan Liu
Dan.Liu at STATE.MN.US
Fri Feb 18 12:35:48 EST 2005
Hi all,
I am trying MySQL Join with dbase shapefile. The errors I get are:
Error in msDrawMap(): Failed to draw layer named 'county'.
Error in msDBFGetItemIndex(): Item 'JOIN1_num' not found.
Below is the layer with JOIN in map file. Does anybody know what is
wrong? Thanks.
LAYER
NAME county
TYPE POLYGON
STATUS DEFAULT
DATA county
CLASSITEM MLMIS_CTY
JOIN
CONNECTIONTYPE mysql
CONNECTION "localhost:myusername:mypw:dbname"
TABLE "county"
TO "num"
NAME "JOIN1"
FROM "MLMIS_CTY"
END
CLASS
NAME "class 6"
EXPRESSION ([JOIN1_num]>30)
COLOR 236 0 0
OUTLINECOLOR 0 0 0
END
Dan
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050218/164fe22b/attachment.html
