map projection problem
blaise
bpicinbono at WORLDONLINE.FR
Mon Feb 21 09:04:58 EST 2005
Not very familiar wit Projection's use, but your EXTENT datas seems strange.
Have you tryed to open your "boundairies" shape file in ArcView to look at
the extent ?
First, as seemed to be set in your mapfile, your "boundairies" shape file
should stand in your /var/www/tmp directory. (bit strange, by the way, as it
seems to be also your temporary images directory).
Second, if you can't figure out your shapefile extent, send your shape file
(esri shape, I suppose), and I'll try to find the right extent.
blaise
Le lundi 21 Février 2005 14:43, Indictrans Team a écrit :
> Dear Sir,
> We have installed Mapserver-4.4.1 on Debian Knoppix version 3.4, Apache
> version 1.3 with support for PostGIS. We have ESRI shapefile named
> maharashtra.shp which is located in /var/www/tmp/ . Below is a mapfile
> that we have created to display this shapefile.
> MAP
> NAME TEST
> STATUS ON
> DEBUG ON
> IMAGETYPE PNG
> SIZE 800 500
> SHAPEPATH "/var/www/tmp"
> FONTSET "font.txt"
> EXTENT 60 50 4270 4480
> UNITS METERS
> IMAGECOLOR 240 240 240
> PROJECTION
> "proj=lcc" "lat_1=32" "lat_2=44" "lat_0=38" "lon_0=-100"
> "x_0=0" "y_0=0" "ellps=GRS80" "datum=NAD83"
> END
> WEB
> IMAGEPATH "/var/www/tmp/"
> IMAGEURL "/tmp/"
> LOG "/var/www/tmp/log.txt"
> END
> # LAYER
> # NAME "Nighttime lights"
> # TYPE RASTER
> # STATUS ON
> # DATA "/var/www/tmp/maharashtra.shp"
> # END
> LAYER
> NAME "credits"
> STATUS DEFAULT
> TRANSFORM FALSE
> TYPE ANNOTATION
> FEATURE
> POINTS
> 20 400
> END
> TEXT
> 'नमस्ते, आपले
> स्वागत
> आहे'
> END
> CLASS
> NAME 'AREA'
> COLOR 202 1 2
> LABEL
> TYPE truetype
> FONT Gargi
> ENCODING UTF-8
> SIZE 20
> POSITION CR
> COLOR 0 0 0
> END
> END
> END
> LAYER
> NAME "boundaries"
> TYPE POLYGON
> STATUS ON
> DATA "maharashtra"
> #COLOR 233 342 123
> PROJECTION
> "proj=latlong"
> "ellps=GRS80"
> "datum=NAD83"
> END
> CLASS
> NAME "US states"
> OUTLINECOLOR 122 234 50
> COLOR 255 255 0
> SYMBOL 0
> END
> END
> END
> We have kept this mapfile in /home/indictrans/gis/mapserverdocs/workshop
> . When we run this file using the following URL:
> http://localhost/cgi-bin/mapserv?MODE=map&MAP=/home/indictrans/gis/mapserve
>rdocs/workshop/font.map&layer=boundries
> We get only the text layer ( Unicode characters) on the output screen
> but the image of maharashtra map (ie the shape file of maharashtra ) is
> not
> displayed and there is no error message also.
> It is because of values of projection parameters and the extent values
> of map? If yes what it should be?
> Please help us in overcoming this problem as soon as possible.
> with regards
> Supriya
> Indictrans Team
