blank map when a layer is defined from php
Shashi Gireddy
gireddy at GMAIL.COM
Mon Feb 21 16:29:41 EST 2005
Hi all,
Thank you steven and Stephen for helping me in removing label
overlapping.I really appreciate your help. I am perfectly able to
join the geometry object with external database. Now I want to make
everything dynamic, i.e generate layers dynamically from php. I had a
problem doing so.
I am getting a blank map when i tried to generate layers dynamically
from php, here is my code
$map_path="c:/ms/map_files/";
$map_file="Test.map";
$map = ms_newMapObj($map_path.$map_file);
$layer = ms_newLayerObj($map);
$lname="counties";
$layer->set(name, $lname);
$layer->set(connectiontype, "postgis");
$layer->set(connection, "user=root password=c3n5u5 dbname=census
host=localhost");
$layer->set(data, "the_geom from calhoun_qry1 using srid=-1");
$layer->set(type, MS_POLYGON);
$layer->set(status, MS_DEFAULT);
$class = ms_newClassObj($layer);
$class->set(name, "class1");
$class->setexpression("[p001001]");
$style = ms_newStyleObj($class);
$style->color->setRGB(10,100,10);
$i= $map->save("c:/inetpub/wwwroot/tmp/Test.map");
if ($i != -1){
$image=$map->draw();
//$map->{imagecolor}= $map->addColor(0,0,255);
$image_url=$image->saveWebImage();
here is the error messages:
Warning: [MapServer Error]: msDrawMap(): Failed to draw layer named
'(null)'. in c:\inetpub\wwwroot\mapExamples\map3.php on line 22
Warning: [MapServer Error]: msSHPOpenFile(): (c:/ms/map_files/the geom
from counties) in c:\inetpub\wwwroot\mapExamples\map3.php on line 22
Fatal error: Call to a member function on a non-object in
c:\inetpub\wwwroot\mapExamples\map3.php on line 24
the worning message is not looking relevant c:/ms/map_files/the geom from .....
can anybody help me please....
Shashi Kiran Reddy. Gireddy,
Graduate Assistant,
CBER, University of Alabama.
http://www.cs.ua.edu/shashi
Home: 205-752-5137 Cell: 205-657-1438
