MySQL decimal field rounded to nearest integer
Stephane Lessard
LESSARDST at DFO-MPO.GC.CA
Wed Feb 23 09:49:21 EST 2005
Frank,
> First, to confirm, you see this problem when using ogr to
> access MySQL tables via ODBC, is that right? So the issue is
> with decimal field handling in the OGR ODBC driver?
That is correct.
> An "ogrinfo" report for the table in question - along with a
> Mysql dump of the field definitions would be helpful ...
> ideally in a GDAL/OGR bugzilla report.
Here's what ogrinfo returns for 5 fields:
Longueur (Real) = 5
Largeur (Real) = 5
Profondeur (Real) = 11
Secteur (Integer) = 3
URL (String) = http://www.marinfo.gc.ca/GEDSite/PDF/Q5173-04.pdf
And here's the definition from MySQL:
'Longueur', 'decimal(8,3)'
'Largeur', 'decimal(8,3)'
'Profondeur', 'decimal(8,3)'
'Secteur', 'int(11)'
'URL', 'varchar(255)'
> The code responsible for field type classification for OGRs
> ODBC driver is in:
> gdal/ogr/ogrsf_frmts/odbc/ogrodbclayer.cpp
> The method is OGRODBCLayer::BuildFeatureDefn().
> There is handling specifically for the ODBC types
> SQL_INTEGER, SQL_DECIMAL, SQL_FLOAT, SQL_REAL and SQL_DOUBLE.
> All others are treated as strings.
> The SQL_DECIMAL is supposed to be treated as a generic
> floating point value.
> I need to establish:
> o What OGR field type is getting used for the field.
> o What ODBC (SQL_*) field type code OGR is getting from ODBC
> for the field.
> Also, could you confirm what version of GDAL/OGR you are using?
> 1.2.5?
1.2.5 it is.
> Best regards,
Thanks a lot!
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial
> Programmer for Rent
