PostGIS and POINT layer problem solved!
Marco Marsella
m.marsella at ITWORKS.IT
Wed Feb 23 11:17:48 EST 2005
Paul, the CVS version fixed the problem!
Thank you for the prompt reply and the great work on PostGIS!
Ciao
Marco
On 23 Feb 2005, at 16:37, Paul Ramsey wrote:
> There are some interop problems with the last postgis 'rc' releases and
> mapserver. See if the current cvs snapshot works better for you. A new
> rc should be out shortly, hopefully your problem is gone in the cvs
> version of postgis.
> Paul
> On 23-Feb-05, at 6:57 AM, Marco Marsella wrote:
>> Hi list,
>> I am going crazy about a simple (or so I thought...) POINT layer. The
>> map file fragment is as follows:
>> LAYER
>> NAME "acstats"
>> TYPE POINT
>> STATUS DEFAULT
>> CONNECTIONTYPE POSTGIS
>> CONNECTION "user=guest password=guest dbname=asiacover
>> host=localhost
>> port=5432"
>> DATA "the_geom from asiacover.stations"
>> CLASS
>> OUTLINECOLOR 255 0 0
>> COLOR 10 10 10
>> SYMBOL 'circle'
>> SIZE 10
>> END
>> PROJECTION "init=epsg:4326" END
>> EXTENT 41.82 -20.15 100.4 22.85
>> END
>> SYMBOL
>> NAME 'circle'
>> TYPE ELLIPSE
>> POINTS 1 1 END
>> FILLED TRUE
>> END
>> The query is executed and 55 points are returned (I tried it manually
>> copying from the Postgres log) but nothing gets drawn on the map. The
>> table content, exported as a shapefile, draws nicely with the same
>> CLASS. But I cannot find any way to make those 55 points show up on my
>> map!
>> I must be missing something obvious, please help!
>> TIA
>> Marco
