RES: [UMN_MAPSERVER-USERS] RES: [UMN_MAPSERVER-USERS]
PHP/Mapscript Crash...
Murilo Lacerda Yoshida
murilo.yoshida at AGX.COM.BR
Thu Feb 24 10:39:22 EST 2005
Just a note .. I'm using php 5.0.2 as na apache dso, and mapsever
4.4.1.
-----Mensagem original-----
De: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] Em
nome de Murilo Lacerda Yoshida
Enviada em: quinta-feira, 24 de fevereiro de 2005 12:18
Para: MAPSERVER-USERS at LISTS.UMN.EDU
Assunto: [UMN_MAPSERVER-USERS] RES: [UMN_MAPSERVER-USERS] PHP/Mapscript
Crash...
Hi Benoit and Corey,
I have this same bug also, but I don't use Chameleon. I'm going to try
a solution now, if you want you can try it to ...
Check if your php is configured with --enable-sigchild ... if not (my
case) compile it again with it.
Hope that helps,
Murilo
nome de Benoît Toutain
Enviada em: quinta-feira, 24 de fevereiro de 2005 09:55
Assunto: Re: [UMN_MAPSERVER-USERS] PHP/Mapscript Crash...
Hi Corey,
I have the same pb as you.
Here is my configuration obtained with <?php
dl('php_mapscript.so');phpinfo(); ?>
MapServer version 4.2.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SWF
SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7 INPUT=POSTGIS
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
($Revision: 1.194.2.6 $ $Date: 2004/08/25 16:27:43 $)
Is not there compatibity problems with freetype libraray and another one
Hope everybody can show us the right way ;-)
Best regards,
Benoît
c p a écrit :
>All,
>I'm hoping someone here can help or can point me to a more appropriate
>forum. I've been having problems getting the samples that ship with
>Chameleon v2.0 fully functional. When I attempt to view one of the
>sample maps I'm getting a segmentation fault:
>==> error_log <==
>[Wed Feb 23 15:59:59 2005] [notice] child pid 18222 exit signal
>Segmentation fault (11)
>By enabling/disabling different layers I was able to narrow the
>problem down to the popplace layer and specifically the FONT, TYPE &
>SIZE tags (which specify a truetype font) inside the LABEL definition.
> Commenting out these three tags result in the layer displaying
>(albeit with the default bitmap font). Although I've narrowed what
>triggers the crash I still have no idea how to rectify the problem.
>I'm further puzzled by the fact that when I use shp2img to render the
>map it works fine which seems to suggest the problem is specific to
>the php/mapscript module?
>I'm running Fedora Core 2 & Mapserver v4.4.1 using the RPMs hosted at
>the Mapping Hacks website (http://mappinghacks.com/rpm/). I've
>attached the chameleon.map file in case that helps.
>Any help would be appreciated.
>Thanks,
>Corey
