[UMN_MAPSERVER-USERS] IIS Config problem
Ken Lord
kenlord at GMAIL.COM
Thu Feb 24 15:28:25 EST 2005
Your dll's appear to be fine, I get the same message when I run
mapserv.exe from dos.
I know i've had the http headers error before. But i haven't been able
to recall what I did to fix it yet.
-Ken
On Thu, 24 Feb 2005 15:12:18 -0500, Fortin,Nicolas [SteFoy]
<nicolas.fortin at ec.gc.ca> wrote:
> Hi
> You got this error while running the demo!?
> I sometimes got it when I call an Oracle Spatial layer alone. Unfortunately I didn't find the source of it yet.
> One thing I did to make sure it was not IIS's fault was to create gif from the mapfile with shp2img utility.
> Example:
> C:\>shp2img -m "C:\path\to\map\file.map" -o img1.gif -l [layer]
> Greetings
> Nicolas
> -----Message d'origine-----
> De : UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] De la part de V P
> Envoyé : Thursday, February 24, 2005 3:02 PM
> À : MAPSERVER-USERS at LISTS.UMN.EDU
> Objet : Re: [UMN_MAPSERVER-USERS] IIS Config problem
> Hi. I ran the mapserv.exe from the Dos prompt. This is what it gave back..
> 'This script can only be used to decode form results and
> should be initiated as a CGI process via a httpd server'
> It seems to be working. I think.
> As far as the dll's go, I specified the path for them in the PATH of the system environment. The path was set as c:\mapserver\bin. The proj folder was specified under a new variable called PROJ_LIB.. in the system environment as well.
> I'm pretty sure I did everything correctly. Maybe I'm overlooking something very small.. Any more ideas? Thanks a great deal.
