PHP/Mapscript Crash...
Benoît Toutain bf.toutain at FREE.FR
Fri Feb 25 03:22:59 EST 2005
I commented the extension=gd.so line in my php.ini and restarted apache
and now it works.
No more crash for me too :-)
Thanks a lot
Best regards
Benoît
Constantin Cristian a écrit :
> I got the same problem, I googled for some answers:
>> Use phpinfo() to see if PHP has GD enabled, if it does then either
>> disable the PHP GD extension or make sure that both PHP and MapScript
>> use the same GD version.  Also make sure that there is only one copy
>> of libgd.so and of the GD headers on your system.
> So I rebuilt my php installation and this time I used the gd that used to
> build mapscript rather then the bundled php gd
> and surprise... it doesn't crash anymore.
> ----- Original Message -----
> From: "c p" <cplists at GMAIL.COM>
> To: <MAPSERVER-USERS at LISTS.UMN.EDU>
> Sent: Thursday, February 24, 2005 7:47 PM
> Subject: Re: [UMN_MAPSERVER-USERS] PHP/Mapscript Crash...
> Benoit,
> Well at least there's someone else to share my pain. :P  After doing
> some more reading today I realized I wasn't running php as a cgi but
> as an apache DSO so I thought that must be my problem.  Is it still
> true that PHP/Mapscript v4.4.1 still must be run as a cgi?  Anyway, I
> reconfigured Apache to call php as a cgi but that did not resolve the
> crash. :(
> Regards,
> Corey
> On Thu, 24 Feb 2005 13:54:54 +0100, Benoît Toutain <bf.toutain at free.fr>
> wrote:
>> Hi Corey,
>> I have the same pb as you.
>> Here is my configuration obtained with <?php
>> dl('php_mapscript.so');phpinfo(); ?>
>> MapServer version 4.2.5 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SWF
>> SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7 INPUT=POSTGIS
>> INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>> ($Revision: 1.194.2.6 $ $Date: 2004/08/25 16:27:43 $)
>> Is not there compatibity problems with freetype libraray and another
>> one ?
>> Hope everybody can show us the right way ;-)
>> Best regards,
>> Benoît
>> c p a écrit :
>> >All,
>> >I'm hoping someone here can help or can point me to a more appropriate
>> >forum.  I've been having problems getting the samples that ship with
>> >Chameleon v2.0 fully functional.  When I attempt to view one of the
>> >sample maps I'm getting a segmentation fault:
>> >==> error_log <==
>> >[Wed Feb 23 15:59:59 2005] [notice] child pid 18222 exit signal
>> >Segmentation fault (11)
>> >By enabling/disabling different layers I was able to narrow the
>> >problem down to the popplace layer and specifically the FONT, TYPE &
>> >SIZE tags (which specify a truetype font) inside the LABEL definition.
>> > Commenting out these three tags result in the layer displaying
>> >(albeit with the default bitmap font).  Although I've narrowed what
>> >triggers the crash I still have no idea how to rectify the problem.
>> >I'm further puzzled by the fact that when I use shp2img to render the
>> >map it works fine which seems to suggest the problem is specific to
>> >the php/mapscript module?
>> >I'm running Fedora Core 2 & Mapserver v4.4.1 using the RPMs hosted at
>> >the Mapping Hacks website (http://mappinghacks.com/rpm/).  I've
>> >attached the chameleon.map file in case that helps.
>> >Any help would be appreciated.
>> >Thanks,
>> >Corey
