Image Resolution
Kristjan Annus
kristjan at TARKVARASTUUDIO.EE
Fri Feb 25 04:32:28 EST 2005
What do you want to achieve with it? If you want to have a scaled
printout, then
you could use html and styles instead.
<img src="image.gif" border=0 style="width:15cm;height;15cm">
Kristjan
>Hi,
>maybe you can use the resolution property of the map object? Default is 72
>pixels per inch.
>Best regards,
>Bart
>>Hi all,
>>Is there any easy mean to change image resolution of images produced by
>>mapserver with PHP/Mapscript ?
>>I done it by modifying the size attribute in my map file, but I must
>>change size of fonts and symbols too. I'd like to do it automatically.
>>Thanks for your help,
>>Benoît
