Query with dates in
Frank Warmerdam
fwarmerdam at GMAIL.COM
Mon Feb 28 15:40:53 EST 2005
On Mon, 28 Feb 2005 21:30:53 +0100, Roberto Bianconi
<roberto.bianconi at gmail.com> wrote:
> Hi,
> I have a shp file where data in the dbf associated are rows like this
> (field names in first row):
> CODE, BEGIN, END, VALUE
> A1, 2002-10-03T09:30:00, 2002-10-04T09:30:00, 60.
> A2, 2002-10-03T09:30:00, 2002-10-05T09:30:00, 60.
> Everything works if I just retrieve CODEs with:
> CLASS
> SYMBOL "cross"
> EXPRESSION ([VALUE] > 50. and [VALUE] <= 75.)
> COLOR 70 255 0
> OUTLINECOLOR 0 0 0
> END
> However, if I query on dates too, then nothing is retrieved:
> CLASS
> SYMBOL "cross"
> EXPRESSION ([VALUE] > 50. and [VALUE] <= 75. and [BEGIN] <
> '2002-10-06T18:00:00')
> COLOR 70 255 0
> OUTLINECOLOR 0 0 0
> END
> I've also tried the '2002-10-06 09:30' format, but no way...
Roberto,
Steve would know better, but aren't expressions just evaluated as simple
arithmetic comparisons when you use < or >? Wouldn't
'2002-10-06T18:00:00' just evaluate to the number 2002? In
which case only records from before 2002 would be returned.
If you want smart date handling I think you need to accomplish
it somehow else. I could be wrong about the issue of course.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
