Query with dates in
Roberto Bianconi
roberto.bianconi at GMAIL.COM
Mon Feb 28 15:52:26 EST 2005
Hi Frank,
I've now tried this:
CLASS
# 1
SYMBOL "cross"
EXPRESSION ([VALUE] > 50. and [VALUE] <= 75. and [BEGIN] < 3000)
COLOR 70 255 0
OUTLINECOLOR 0 0 0
END
and this:
CLASS
# 1
SYMBOL "cross"
EXPRESSION ([VALUE] > 50. and [VALUE] <= 75. and [BEGIN] lt '3000')
COLOR 70 255 0
OUTLINECOLOR 0 0 0
END
but stilI I don't get anything.
On Mon, 28 Feb 2005 15:40:53 -0500, Frank Warmerdam
<fwarmerdam at gmail.com> wrote:
> On Mon, 28 Feb 2005 21:30:53 +0100, Roberto Bianconi
> <roberto.bianconi at gmail.com> wrote:
> > Hi,
> > I have a shp file where data in the dbf associated are rows like this
> > (field names in first row):
> > CODE, BEGIN, END, VALUE
> > A1, 2002-10-03T09:30:00, 2002-10-04T09:30:00, 60.
> > A2, 2002-10-03T09:30:00, 2002-10-05T09:30:00, 60.
> > Everything works if I just retrieve CODEs with:
> > CLASS
> > SYMBOL "cross"
> > EXPRESSION ([VALUE] > 50. and [VALUE] <= 75.)
> > COLOR 70 255 0
> > OUTLINECOLOR 0 0 0
> > END
> > However, if I query on dates too, then nothing is retrieved:
> > CLASS
> > SYMBOL "cross"
> > '2002-10-06T18:00:00')
> > COLOR 70 255 0
> > OUTLINECOLOR 0 0 0
> > END
> > I've also tried the '2002-10-06 09:30' format, but no way...
> Roberto,
> Steve would know better, but aren't expressions just evaluated as simple
> arithmetic comparisons when you use < or >? Wouldn't
> '2002-10-06T18:00:00' just evaluate to the number 2002? In
> which case only records from before 2002 would be returned.
> If you want smart date handling I think you need to accomplish
> it somehow else. I could be wrong about the issue of course.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
