time queries with mapserver 4.4.1
Trond Michelsen
trondmm-mapserver at CRUSADERS.NO
Wed Jan 19 09:31:01 EST 2005
Hi.
I'm still unsuccessful in trying to understand how to make a time
query in mapserver 4.4.1, and I'd appreciate any help on the subject.
I have several layers that I access with WMS through mapserver, and
some of these layers can show data for different dates and times.
Here's an example of a layer definition in my map file.
--8<--
LAYER
NAME "wind"
STATUS ON
TYPE RASTER
OFFSITE 255 255 255
CONNECTION "http://wmsserver/cgi-bin/wms.cgi?"
CONNECTIONTYPE WMS
PROJECTION
"proj=stere"
"a=6371000"
"b=6371000"
"lat_0=90"
"lat_ts=60"
"lon_0=0"
END
METADATA
"wms_name" "wind"
"wms_server_version" "1.1.1"
"wms_formatlist" "image/png"
"wms_format" "image/png"
END
END
--8<--
I've seen suggestions that it's possible to use %var% for every
parameter in the query string, so I tried to add "wms_time %time%" to
the metadata, and then add a select-box with appropriate dates to the
web-page, but that passed "time=%25time%25" to the WMS-server.
Being able to make queries at all is of course the most important
issue I'd like to have solved, but I'm also a bit curious about how I
define which times that are appropriate. How do I configure the
mapfile, so that mapserv.cgi adds the proper <dimension>-tag to a
GetCapabilities response? Also, is it possible to get mapserv.cgi to
automatically fill inn available dates in the web template, or will I
have to change it every time the available dates changes?
Trond Michelsen
