projection woes
Matthew Perry
mtperry78 at SBCGLOBAL.NET
Tue Jan 25 12:31:55 EST 2005
You might try using "init=epsg:26717" instead of
"init=EPSG:26717". I know that some versions of
mapserver are picky about this capitalization.
Other than that, your mapfile looks like it should
work.
Matt Perry
Humboldt State University
--- Mark Adams <markadams at CUESTASYS.COM> wrote:
> I've included my map file below.
> Regarding Stephen Woodbridge's response, the data in
> all files is in zone 17, the only difference is the
> datum; and I can confirm that the data really is
> there. As I indicated, if I don't include the
> projection block on the layer the data shows, just
> shifted because of the different datum. (Also
> working with it in ArcMap etc.)
> If it's likely that that I either don't have the
> right files, or for some reason they aren't being
> found, how can I test this, and how do I know which
> files I need? Incidentally, I installed proj.4 from
> the proj446_win32_bin.zip distribution; and I'm
> running on Win2000, IIS 5.
> -----map file------
> # Start of map file
> MAP
> NAME "MVCA_GeoPortal"
> STATUS ON
> EXTENT 433350 4813769 546722 4889572
> SIZE 682 456
> #SIZE 674 474
> SHAPEPATH "..\Data\Shapefiles"
> #TEMPLATEPATTERN "MVCA_GeoPortal"
> SYMBOLSET "GeoPortal.symbols"
> #fonset added AD 13-Jul-04
> FONTSET "GeoPortal.fonts"
> #IMAGETYPE PNG
> #IMAGETYPE swf
> #IMAGETYPE png24bit
> IMAGETYPE gif
> #IMAGECOLOR 255 255 255
> UNITS METERS
> OUTPUTFORMAT
> NAME gif
> DRIVER "GD/GIF"
> MIMETYPE "image/gif"
> IMAGEMODE PC256
> EXTENSION "gif"
> TRANSPARENT ON
> END
> OUTPUTFORMAT
> NAME png24bit
> DRIVER "GD/PNG"
> MIMETYPE "image/png"
> IMAGEMODE rgb
> FORMATOPTION "INTERLACE=OFF"
> END
> OUTPUTFORMAT
> NAME swf
> DRIVER "SWF"
> MIMETYPE "application/x-shockwave-flash"
> EXTENSION "swf"
> IMAGEMODE PC256
> FORMATOPTION "OUTPUT_MOVIE=SINGLE"
> END
> # Start of web interface definition (including WMS
> enabling metadata)
> WEB
> #MINSCALE 500
> MAXSCALE 1550000
> IMAGEPATH "C:\Inetpub\wwwroot\tmp\"
> IMAGEURL "/tmp/"
> HEADER "templates/header.html"
> FOOTER "templates/footer.html"
> TEMPLATE "set in index.html"
> METADATA
> "WMS_TITLE" "MVCA MapServer GeoPortal"
> "WMS_ABSTRACT" "This is MapServer
> application using data from Maitland Valley
> Conservation Authority."
> "WMS_ACCESSCONSTRAINTS" "none"
> "WMS_ONLINERESOURCE"
"http://navigator/cgi-bin/mapserv.exe?map=C:\Inetpub\wwwroot\mapserver_demos\MVCA_GeoPortal\config\MVCA_GeoPortal.map&"
> "WMS_SRS" "EPSG:26717"
> END
> END
> # Start of reference map
> REFERENCE
> IMAGE "reference.png"
> EXTENT 433350 4813769 534792 4889572
> SIZE 168 118
> #SIZE 84 59
> STATUS ON
> #COLOR 175 175 208
> COLOR -1 -1 -1
> OUTLINECOLOR 175 175 208
> MINBOXSIZE 5
> MAXBOXSIZE 500
> MARKER "star"
> MARKERSIZE 8
> END
> # Projection definition, consult the PROJ.4
> documentation for parameter discussion
> PROJECTION
> # proj=utm
> # ellps=GRS80
> # zone=15
> # north
> # no_defs
> # OR:
> # init=epsg:26915
> "init=EPSG:26717"
> END
> # Start of legend
> LEGEND
> STATUS ON
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> TEMPLATE "legend.html"
> END
> # Start of scalebar
> SCALEBAR
> STATUS ON
> POSITION LR
> POSTLABELCACHE TRUE
> #BACKGROUNDCOLOR 166 202 240
> BACKGROUNDCOLOR 254 219 67
> COLOR 0 0 156
> OUTLINECOLOR 166 202 240
> TRANSPARENT ON
> #IMAGECOLOR 0 0 0
> UNITS KILOMETERS
> INTERVALS 4
> SIZE 200 8
> STYLE 0
> LABEL
> SIZE SMALL
> COLOR 0 0 156
> ANTIALIAS TRUE
> OUTLINECOLOR 254 219 67
> #SHADOWCOLOR 166 202 240
> #SHADOWSIZE 3 3
> END
> END
> # Start of layer definitions
> #1
> LAYER
> NAME "Municipal_Boundaries"
> #GROUP "MUNICIPALBOUNDARY"
> STATUS ON
> DATA "municip_new2001"
> TYPE POLYGON
> TRANSPARENCY 50
> TEMPLATE "null"
> LABELITEM "township"
> LABELMINSCALE 300000
> # LABELANGLEITEM
> METADATA
> "WMS_TITLE" "Municipal Boundaries MVCA"
> "WMS_ABSTRACT" "Depicts Municipal
> Boundaries in MVCA watershed as of 2001."
> END
> CLASS
> LABEL
> TYPE truetype
> FONT "Arial_bold"
> SIZE 8
> POSITION CC
> COLOR 128 128 64
> #ANGLE AUTO
> ANTIALIAS TRUE
> END
> STYLE
> #COLOR 247 235 208
> SYMBOL 'circle'
> OUTLINECOLOR 128 128 64
> SIZE 4
> END
=== message truncated ===
