Serving hillshaded maps
Martin Tomko m.tomko at PGRAD.UNIMELB.EDU.AU
Wed Jul 6 02:26:17 EDT 2005
I had some experience with it in my previous project - www.geoportal.sk
the approach you mentionned is the one used, works well. Combined with
transparency, you can use it nicely with other elements.
There is an english version of the page, so have a look. The title page
is only in slovak though, so just click on the first option (= agree, it
is a copyright agreement).
Click on english version in the top right corner, and then select a
transparent digital model from the digital models group. It you overlay
it with any other data, you will see how it behaves.
Martin
BTW, that's the official geoportal of the Slovak National Mapping Agency.
!!!!!!!!Do not send any emails to
mtomko at sunrise.sli.unimelb.edu.au anymore!!!
Use m.tomko at pgrad.unimelb.edu.au as my main
email address.
Ing. Martin Tomko
PhD. candidate
CRC for Spatial Information
Department of Geomatics
University of Melbourne
Victoria 3010
Australia
phone +61 3 8344 9179
fax   +61 3 9349 5185
email m.tomko at pgrad.unimelb.edu.au
url   http://www.geom.unimelb.edu.au/tomko
url   http://www.spatialinformationscience.org
url   http://www.crcsi.com.au
MAPSERVER-USERS automatic digest system wrote:
> Skip repetitive navigational links <#skipnavlinks>
> L-Soft - Home of the LISTSERV mailing list manager
> <http://www.lsoft.com> LISTSERV(R) 14.3
>     MAPSERVER-USERS Digest - 4 Jul 2005 to 5 Jul 2005 (#2005-192)
>       Table of contents:
>     * [UNCLASSIFIED]RE: [UMN_MAPSERVER-USERS] UTM at the zone's boundar
>       y. <#S1>
>     * transparency not working in dynamic layer <#S2> (2)
>     * ??: [UMN_MAPSERVER-USERS] question abo ut the installation of
>       mapserver <#S3> (2)
>     * MapFile for 250 layers (MS_MAXLAYERS) <#S4> (2)
>     * SLD & Spatial filter <#S5> (4)
>     * pixmap symbol <#S6>
>     * A flash question about Mapserver's SWF output <#S7>
>     * Raster Layer, Extent, etc. <#S8> (5)
>     * Tif tiles display, but small in size <#S9>
>     * Connect to ESRI Personal Geodatabase <#S10> (3)
>     * Serving hillshaded maps <#S11>
>    1. [UNCLASSIFIED]RE: [UMN_MAPSERVER-USERS] UTM at the zone's boundar y.
>           * Re: [UNCLASSIFIED]RE: [UMN_MAPSERVER-USERS] UTM at the
>             zone's boundar y.
>             <mailbox:///C|/Documents%20and%20Settings/mtomko/Application%20Data/Thunderbird/Profiles/hb3vh28n.default/Mail/Local%20Folders/Inbox?number=202680998&header=quotebody&part=1.2>
>             (07/04)
>             *From:* Krung Saengpole <saengpole at YAHOO.COM>
>    2. transparency not working in dynamic layer
>           * Re: transparency not working in dynamic layer
>             <mailbox:///C|/Documents%20and%20Settings/mtomko/Application%20Data/Thunderbird/Profiles/hb3vh28n.default/Mail/Local%20Folders/Inbox?number=202680998&header=quotebody&part=1.3>
>             (07/05)
>             *From:* Lowell Filak <lfilak at MEDINACO.ORG>
>             <mailbox:///C|/Documents%20and%20Settings/mtomko/Application%20Data/Thunderbird/Profiles/hb3vh28n.default/Mail/Local%20Folders/Inbox?number=202680998&header=quotebody&part=1.21>
>             (07/05)
>             *From:* Steve Lime <steve.lime at DNR.STATE.MN.US>
>    3. ??: [UMN_MAPSERVER-USERS] question abo ut the installation of
>       mapserver
>           * Re: ??: [UMN_MAPSERVER-USERS] question abo ut the
>             installation of mapserver
>             <mailbox:///C|/Documents%20and%20Settings/mtomko/Application%20Data/Thunderbird/Profiles/hb3vh28n.default/Mail/Local%20Folders/Inbox?number=202680998&header=quotebody&part=1.4>
>             (07/05)
>             *From:* "Fawcett, David" <David.Fawcett at STATE.MN.US>
>             <mailbox:///C|/Documents%20and%20Settings/mtomko/Application%20Data/Thunderbird/Profiles/hb3vh28n.default/Mail/Local%20Folders/Inbox?number=202680998&header=quotebody&part=1.5>
>             (07/05)
>             *From:* Howard Butler <hobu at IASTATE.EDU>
>    4. MapFile for 250 layers (MS_MAXLAYERS)
>             <mailbox:///C|/Documents%20and%20Settings/mtomko/Application%20Data/Thunderbird/Profiles/hb3vh28n.default/Mail/Local%20Folders/Inbox?number=202680998&header=quotebody&part=1.6>
>             (07/05)
>             *From:* Gabriel Cloutier <gabriel.cloutier at RNCAN.GC.CA>
>           * Re: MapFile for 250 layers (MS_MAXLAYERS)
>             <mailbox:///C|/Documents%20and%20Settings/mtomko/Application%20Data/Thunderbird/Profiles/hb3vh28n.default/Mail/Local%20Folders/Inbox?number=202680998&header=quotebody&part=1.8>
>             (07/05)
>    5. SLD & Spatial filter
>             <mailbox:///C|/Documents%20and%20Settings/mtomko/Application%20Data/Thunderbird/Profiles/hb3vh28n.default/Mail/Local%20Folders/Inbox?number=202680998&header=quotebody&part=1.7>
>             (07/05)
>             *From:* François Prunayre <fx.prunayre at OIEAU.FR>
>           * Re: SLD & Spatial filter
>             <mailbox:///C|/Documents%20and%20Settings/mtomko/Application%20Data/Thunderbird/Profiles/hb3vh28n.default/Mail/Local%20Folders/Inbox?number=202680998&header=quotebody&part=1.10>
>             (07/05)
>             *From:* Bart van den Eijnden <bartvde at XS4ALL.NL>
>             <mailbox:///C|/Documents%20and%20Settings/mtomko/Application%20Data/Thunderbird/Profiles/hb3vh28n.default/Mail/Local%20Folders/Inbox?number=202680998&header=quotebody&part=1.17>
>             (07/05)
>             *From:* "Kralidis,Tom [Burlington]" <Tom.Kralidis at EC.GC.CA>
>             <mailbox:///C|/Documents%20and%20Settings/mtomko/Application%20Data/Thunderbird/Profiles/hb3vh28n.default/Mail/Local%20Folders/Inbox?number=202680998&header=quotebody&part=1.20>
>             (07/05)
>             *From:* Yewondwossen Assefa <assefa at DMSOLUTIONS.CA>
>    6. pixmap symbol
>           * pixmap symbol
>             <mailbox:///C|/Documents%20and%20Settings/mtomko/Application%20Data/Thunderbird/Profiles/hb3vh28n.default/Mail/Local%20Folders/Inbox?number=202680998&header=quotebody&part=1.9>
>             (07/05)
>             *From:* Lluís Garcia i Mestres <lluisgm at GMAIL.COM>
>    7. A flash question about Mapserver's SWF output
>             <mailbox:///C|/Documents%20and%20Settings/mtomko/Application%20Data/Thunderbird/Profiles/hb3vh28n.default/Mail/Local%20Folders/Inbox?number=202680998&header=quotebody&part=1.11>
>             (07/05)
>             *From:* Jay Austin <jayaustin at GMAIL.COM>
>    8. Raster Layer, Extent, etc.
>             <mailbox:///C|/Documents%20and%20Settings/mtomko/Application%20Data/Thunderbird/Profiles/hb3vh28n.default/Mail/Local%20Folders/Inbox?number=202680998&header=quotebody&part=1.12>
>             (07/05)
>             *From:* Ian Harding <iharding at TPCHD.ORG>
>           * Re: Raster Layer, Extent, etc.
>             <mailbox:///C|/Documents%20and%20Settings/mtomko/Application%20Data/Thunderbird/Profiles/hb3vh28n.default/Mail/Local%20Folders/Inbox?number=202680998&header=quotebody&part=1.13>
>             (07/05)
>             <mailbox:///C|/Documents%20and%20Settings/mtomko/Application%20Data/Thunderbird/Profiles/hb3vh28n.default/Mail/Local%20Folders/Inbox?number=202680998&header=quotebody&part=1.14>
>             (07/05)
>             <mailbox:///C|/Documents%20and%20Settings/mtomko/Application%20Data/Thunderbird/Profiles/hb3vh28n.default/Mail/Local%20Folders/Inbox?number=202680998&header=quotebody&part=1.15>
>             (07/05)
>             <mailbox:///C|/Documents%20and%20Settings/mtomko/Application%20Data/Thunderbird/Profiles/hb3vh28n.default/Mail/Local%20Folders/Inbox?number=202680998&header=quotebody&part=1.18>
>             (07/05)
>    9. Tif tiles display, but small in size
>             <mailbox:///C|/Documents%20and%20Settings/mtomko/Application%20Data/Thunderbird/Profiles/hb3vh28n.default/Mail/Local%20Folders/Inbox?number=202680998&header=quotebody&part=1.16>
>             (07/05)
>             *From:* Yar Doroshenko <numerous at GMAIL.COM>
>   10. Connect to ESRI Personal Geodatabase
>             <mailbox:///C|/Documents%20and%20Settings/mtomko/Application%20Data/Thunderbird/Profiles/hb3vh28n.default/Mail/Local%20Folders/Inbox?number=202680998&header=quotebody&part=1.19>
>             (07/05)
>             *From:* Ken Lord <kenlord at GMAIL.COM>
>           * Re: Connect to ESRI Personal Geodatabase
>             <mailbox:///C|/Documents%20and%20Settings/mtomko/Application%20Data/Thunderbird/Profiles/hb3vh28n.default/Mail/Local%20Folders/Inbox?number=202680998&header=quotebody&part=1.23>
>             (07/05)
>             *From:* Alex Smith <msestudiente2 at YAHOO.COM>
>             <mailbox:///C|/Documents%20and%20Settings/mtomko/Application%20Data/Thunderbird/Profiles/hb3vh28n.default/Mail/Local%20Folders/Inbox?number=202680998&header=quotebody&part=1.24>
>             (07/05)
>             *From:* Paul Ramsey <pramsey at REFRACTIONS.NET>
>   11. Serving hillshaded maps
>             <mailbox:///C|/Documents%20and%20Settings/mtomko/Application%20Data/Thunderbird/Profiles/hb3vh28n.default/Mail/Local%20Folders/Inbox?number=202680998&header=quotebody&part=1.22>
>             (07/05)
>             *From:* Mike Davis <mike.and.kerry at GMAIL.COM>
> Powered by LISTSERV(R) <http://www.lsoft.com/LISTSERV-powered.html>
> Browse the MAPSERVER-USERS online archives.
> <http://lists.umn.edu/cgi-bin/wa?LIST=MAPSERVER-USERS>
