A flash question about Mapserver's SWF output
Kristjan Annus
kristjan at TARKVARASTUUDIO.EE
Wed Jul 6 02:46:15 EDT 2005
Hello!
I made the container movie, then put one map movie into it and loaded
the map into this movie.
Then if it is requried to pan, then I move the container. It is useful
allso for moving some
additional vector layers at the same time with the map (these layers are
drawn allso to the same container).
You can look at the sample application at:
http://www.tartu.ee/bi_kaart/map.html
Kristjan
Jay Austin wrote:
>Hi, I'm working on a flash app designed to load a mapserver swf and then
>manipulate it (pan, zoom, etc).
>In my flash file I use loadMovie to put the swf into an empty movie clip.
>My ActionScript looks like this...
>myclip_mc.loadMovie("http://myserver.com/cgi-bin/mapserv?map=../htdocs/folder/folder/mapfile.map&mode=map");
>When it loads the swf it puts it in the upper left corner of the stage
>(regardless of where the empty movie clip was placed), and I am unable to
>move it, change it's size it's x-scale etc.
>I can access the variables in the swf, (i.e., _level5.Element[15][0], or
>_level0.myclip_mc.mapObj.layers[0].name) I just can't manipulate the actual
>map. Moving the movie clip the swf was loaded into does nothing.
>Can you please tell me what I'm doing wrong or what name I have to use in
>actionscript to move the physical map.
>Thanks.
