ms_newShapefileObj gives error in mapserver 4.4.2
Julien-Samuel Lacroix
jlacroix at DMSOLUTIONS.CA
Thu Jul 7 09:55:06 EDT 2005
This error message can be output if MapServer is not able to open
gspplan/bespreek.shp or gspplan/bespreek.dbf. From there you have 3
things to check:
Does the shapefile exist?
Does this shapefile have a DBF associated with it?
Is the files are readable by the web user?
Julien
On 07/07/2005 06:15 AM, Joukje wrote:
> Hi list,
> I have a problem with opening a shapefile in php/mapscript since we started
> using mapserver 4.4.2. (php 4.1.2) instead of 4.0.1 (php 4.3.11).
> The following line of php now returns an error:
> $objShapefile = ms_newShapefileObj("gspplan/bespreek", -2);
> Warning: [MapServer Error]: msSHPOpenFile(): (gspplan/bespreek)
> in /project/gspvg/wwwontw/page/object_attributes_edit.phtml on line 80
> Fatal error: Failed to open shapefile gspplan/bespreek
> I also tried opening the shapefile with the full pathname, but the same
> error occurred. Does anyone have an idea what the causes this problem?
> Thanks!
> Joukje
Julien-Samuel Lacroix jlacroix at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
