PC256 color images (I need more quality)
Pericles S. Nacionales
nacional at CBS.UMN.EDU
Fri Jul 8 16:06:20 EDT 2005
I don't quite understand--you're using JPEG as output format and you're
getting a bitmapped image? Try IMAGETYPE PNG24, or define an OUTPUTFORMAT
and use RGB as IMAGEMODE. Check
http://mapserver.gis.umn.edu/doc44/mapfile-reference.html#outputformat for
more info.
Good luck!
-Perry
On Friday 08 July 2005 15:07, Ezequias Rodrigues da Rocha wrote:
> Good afternoon (for some of you)
> I am trying to make Mapserver render a 24bits but it only send to me a 256
> colors image.
> Here some of my Map file:
> ___________________________________________________________________________
>__ ________________
> fontset "/usr/java/jre1.5.0_01/lib/fonts/LucidaTypewriterRegular.ttf"
> imagecolor 255 255 255
> imagetype jpeg
> shapepath "/var/www/cgi-bin/"
> size 600 440
> units meters
> projection
> "int=epsg:29185"
> end
> LAYER
> NAME "Imagem56"
> data "raster/recorte_56.tif"
> STATUS off
> TYPE RASTER
> PROCESSING "DITHER=YES"
> PROCESSING "BANDS=1,2,3"
> PROCESSING "COLOR_MATCH_THRESHOLD=3"
> END
> OUTPUTFORMAT
> NAME jpeg
> DRIVER "GD/JPEG"
> MIMETYPE "image/jpeg"
> IMAGEMODE RGB
> EXTENSION "jpg"
> END
> end # End Map
> Best regards to all
> Ezequias
Conservation Biology Program
University of Minnesota
1530 Cleveland Ave. N., 115GrnH
St. Paul, MN 55108
