Splitting/tiling a raster
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Tue Jul 12 05:47:52 EDT 2005
Hi Stefan,
since gdal_translate has the option to select a subwindow (srcwin) from your sourcefile, you can use it to split your raster file into subimages.
http://www.gdal.org/gdal_utilities.html#gdal_translate
After that, you do use gdaltindex to create a tileindex. That part is described in the raster howto:
http://mapserver.gis.umn.edu/doc44/raster-howto.html
Btw, what is the exact reason you want to split up your raster? Performance?
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Stefan Schwarzer <stefan.schwarzer at GRID.UNEP.CH> 07/12/05 11:39am >>>
this subject is really not new. But I haven't found any real how-to
for the whole story. Perhaps somebody could clarify the steps needed.
when starting with an image of some larger size and when ending with
a tiled raster. Cause I guess that' what has to be done.
- At least I have now one single big raster. As far as I understood I
need to split the big image into smaller ones. But how?
- And then I can use gdaltindex to build the shapefile to define the
tiles. Right?
Thanks for clarification.
