Need help: Annotation layer from Postgis using php
Paul Ramsey pramsey at REFRACTIONS.NET
Tue Jul 12 14:07:10 EDT 2005
Best to ask the users list, Sergey, one-on-one support wears out half
the partners pretty quick :) Oh, and read the mapfile reference. :)
Paul
On 12-Jul-05, at 11:07 AM, Sergey Miltchakov wrote:
> Hello! I fixed all the problems and cleared just about everything out.
> I managed to define and draw a point on the map and to highlight
> the shape
> which contains that point. (Querybypoint helped me).
> Now  I added the date field to my 'vydely' table and want to color the
> shapes depending on the year of this date. Here is my expression
> $tmpclass2[$i]->setexpression("(date_part('year',data_rubki) as
> [foo] =
> 2004)");
> But it returns blank image.
> When instead I use
> $tmpclass2[$i]->setexpression("([id] = 23)");
> Everything works fine.
> Where do I read on using EXPRESSION? Could you please help me or
> give me a
> hint?
> Regards,
> Sergey
>> Why is your data statement set to "id from vydely"? Even though it is
>> an annotation layer, the data statement should still point at the
>> geometry column (the_geom in your case).
>> On a related note: why have an annotation layer, if you are already
>> drawing the polygons? Just add a label object to your polygon layer.
>> On a related, related note: if you want to label using a
>> combination of
>> two columns for the label, a SQL based data statement could be
>> useful.
>> For example:
>> DATA "the_geom from (select gid,the_geom,kvartal || ' ' || id as
>> label
>> from vydely) as foo using unique gid"
