Raster zoom problem with ERDAS Imagine Files
Moen, Paul T.
pmoen at STATE.ND.US
Wed Jul 13 10:33:01 EDT 2005
Thank you Frank,
We are using Mac OS X. I just got the latest gdal via cvs and I will build
and test to see if the problem is solved. If not I will submit a bug.
But first, I want to make sure that I have large file format support
configured. My previous configure was as follows.
/configure --prefix=/MapServer --exec-prefix=/MapServer
--mandir=/MapServer/man --with-libz=/usr --with-libtiff=/MapServer
--with-geotiff=/MapServer --with-jpeg=/MapServer --with-jasper=/MapServer
--with-gif=/MapServer --with-png=/MapServer --without-python --without-ogdi
--with-threads
--with-grass=/MapServer/src/grass57_exp_2004_11_27/dist.powerpc-apple-darwin
7.6.0
I looked at ./configure -help and did not see any reference to imagine files
or large file support. Do I have what I need in the configure that I have
above? Will I have large file support enabled using the above configure?
On 7/13/05 8:47 AM, "Frank Warmerdam" <fwarmerdam at gmail.com> wrote:
Paul,
What platform are you working on? GDAL 1.2.5 is a bit old now. It
is possible an upgrade to GDAL 1.2.6 or GDAL CVS will help. There
have been a few fixes in the decompression code in GDAL's Imagine
reader in the last year or two.
Also, what platform are you on? I am wondering if "large file" support
might not have been enabled at build time. For instance, large files
were not supported on MacOS X with GDAL till quite recently (post 1.2.6).
This is clearly a GDAL problem, so you might just want to open a GDAL
bugzilla entry for the issue and we can pursue it from there.
Best regards,
Thank you,
Paul T. Moen
pmoen at state.nd.us
ND State Water Commission
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050713/58fef92a/attachment.html
