Res: RE: [UMN_MAPSERVER-USERS] Res: Re: [UMN_MAPSERVER-USERS]
Problem to load images
Ed McNierney
ed at TOPOZONE.COM
Thu Jul 14 15:07:46 EDT 2005
Ezequias -
Be sure to be VERY careful about paths, even in email! You said you moved the image to the folder "/raster" - did you mean to "/var/www/cgi-bin/raster"? That would make sense.
And I would agree that if that is what is happening, it is probably a permissions problem on the directory and/or file. The cgi-bin folder is probably not a good place to store your raster data, as it may be accessible to HTTP clients. Most users put their data in a local folder that is accessible to the mapserv CGI program when it is running, but which is NOT accessible via an HTTP request to the Web server.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Ezequias Rodrigues da Rocha
Sent: Thursday, July 14, 2005 12:34 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Res: RE: [UMN_MAPSERVER-USERS] Res: Re: [UMN_MAPSERVER-USERS] Problem to load images
Ed,
It is working now, but let me say what occours:
1- I have the image on the cgi-bin folder
2- My map file is:
shapepath "/var/www/cgi-bin/"
LAYER
NAME "Imagem23"
data "recorte_23.tif"
STATUS default
TYPE RASTER
PROCESSING "DITHER=YES"
PROCESSING "BANDS=1,2,3"
END
3 - The error reported when I try to load on the Browser is:
msDrawMap(): Image handling error. Failed to draw layer named Imagem23'.
msDrawRaster(): Unable to access file. (recorte_23.tif)
4 - a) I copy the image to the folder /raster
b) Change the LAYER parameter to:
data "raster/recorte_23.tif"
5- The image appears on browser
If I didn't make the step 4a the message on step 3 will be repeated.
Does it make any sense ?
Sincerely
Ezequias
-------Mensagem original-------
De: Ed McNierney
Data: 07/14/05 12:41:47
Para: Ezequias Rodrigues da Rocha
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Assunto: RE: [UMN_MAPSERVER-USERS] Res: Re: [UMN_MAPSERVER-USERS] Problem to load images
Ezequias -
OK - you will want to get to a TILEINDEX, I think, if your layers are simply separate images that all belong together as a single set of one type of image.
But you don't need to worry about that now. Just make sure the DATA statement in each LAYER specifies the full pathname.
I suggest you try to get ONE image working properly first, then get the other 115 working. Did you have one working at all?
- Ed
Ed McNierney
ed at topozone.com
(978) 251-4242
Sent: Thursday, July 14, 2005 12:08 PM
Subject: [UMN_MAPSERVER-USERS] Res: Re: [UMN_MAPSERVER-USERS] Problem to load images
I have no TILEINDEX and I don't know how to use it on mapserver.
My map file have yes 116 layers.
Sincerely
Ezequias
De: Ed McNierney
Data: 07/14/05 12:33:15
Para: MAPSERVER-USERS at LISTS.UMN.EDU
Assunto: Re: [UMN_MAPSERVER-USERS] Problem to load images
Ezequias -
Please always reply to the whole list, so everyone can help - thanks!
MapServer may be strange but it should be consistent. Do you have a TILEINDEX for these 116 images or are they each specified in a separate LAYER in your map file? It doesn't matter where the images are (if the permissions are OK) but you should start by putting the full path to each image in either the map file LAYER block or in the TILEINDEX shapefile.
- Ed
Ed McNierney
ed at topozone.com
(978) 251-4242
From: Ezequias Rodrigues da Rocha [mailto:ezequias at recife.pe.gov.br]
Sent: Thursday, July 14, 2005 11:59 AM
To: Ed McNierney
Subject: Res: Re: [UMN_MAPSERVER-USERS] Problem to load images
Ed,
Mapsever works strange. Some file works on the cgi-bin folder others on cgi-bin/raster.
I am working with 116 images too. I don't know if it makes any difference.
Sincerely
Ezequias
De: Ed McNierney
Data: 07/14/05 11:44:53
Ezequias -
This is probably due to the paths to the data. Your error message reports a relative path, which depends on the "current directory" on your server. It is easier to always use full pathnames (starting with a "/") to your data files when you're getting started. Try putting the whole path in your map file to see if that solves the problem.
- Ed
Ed McNierney
ed at topozone.com
(978) 251-4242
Sent: Thursday, July 14, 2005 10:40 AM
Subject: [UMN_MAPSERVER-USERS] Problem to load images
Hi list,
My browser reported the error above:
msDrawRaster(): Unable to access file. (raster/recorte_01.tif)
Any suggestions ?
all my files are -rwxrwxrwx
Atenciosamente (Sincerely)
* www.recife.pe.gov.br
A pior das democracias ainda é melhor do que a melhor das ditaduras The worst of democracies is still better than the better of dictatorships MSN Messenger: ezequias at hotmail.com
