Res: [UMN_MAPSERVER-USERS] Res: Re: [UMN_MAPSERVER-USERS] Problem
to load images
Ezequias Rodrigues da Rocha
ezequias at RECIFE.PE.GOV.BR
Fri Jul 15 15:48:58 EDT 2005
I am on linux System.
-------Mensagem original-------
De: Leandro Dorileo
Data: 07/15/05 03:38:07
Para: MAPSERVER-USERS at LISTS.UMN.EDU
Assunto: [UMN_MAPSERVER-USERS] Res: Re: [UMN_MAPSERVER-USERS] Problem to
load images
Hi Ezequias
Are you working on a unix system? or is it a windows system?
Dorileo
On Thursday 14 July 2005 05:13 pm, Ezequias Rodrigues da Rocha wrote:
> There is no difference. Thake a look on the image I attached and make your
> conclusions.
> Sincerely
> Ezequias
> ps.: I did all the process and the service is running.
> De: Randy James
> Data: 07/14/05 13:16:31
> Para: Ezequias Rodrigues da Rocha
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Assunto: Re: [UMN_MAPSERVER-USERS] Res: RE: [UMN_MAPSERVER-USERS] Res: Re:
> [UMN_MAPSERVER-USERS] Problem to load images
> could be the permissions of the cgi-bin folder? Are the permissions
> different for
> the /raster folder?
> Randy
> --- Ezequias Rodrigues da Rocha <ezequias at RECIFE.PE.GOV.BR> wrote:
> > Ed,
> > It is working now, but let me say what occours:
> > 1- I have the image on the cgi-bin folder
> > 2- My map file is:
> > shapepath "/var/www/cgi-bin/"
> > LAYER
> > NAME "Imagem23"
> > data "recorte_23.tif"
> > STATUS default
> > TYPE RASTER
> > PROCESSING "DITHER=YES"
> > PROCESSING "BANDS=1,2,3"
> > END
> > 3 - The error reported when I try to load on the Browser is:
> > msDrawMap(): Image handling error. Failed to draw layer named
> > Imagem23'.
> > msDrawRaster(): Unable to access file. (recorte_23.tif)
> > 4 - a) I copy the image to the folder /raster
> > b) Change the LAYER parameter to:
> > data "raster/recorte_23.tif"
> > 5- The image appears on browser
> > If I didn't make the step 4a the message on step 3 will be repeated.
> > Does it make any sense ?
> > Sincerely
> > Ezequias
> > De: Ed McNierney
> > Data: 07/14/05 12:41:47
> > Assunto: RE: [UMN_MAPSERVER-USERS] Res: Re: [UMN_MAPSERVER-USERS]
Problem
> to
> > load images
> > Ezequias -
> > OK - you will want to get to a TILEINDEX, I think, if your layers are
> simply
> > separate images that all belong together as a single set of one type of
> > image.
> > But you don't need to worry about that now. Just make sure the DATA
> > statement in each LAYER specifies the full pathname.
> > I suggest you try to get ONE image working properly first, then get the
> > other 115 working. Did you have one working at all?
> > - Ed
> > Ed McNierney
> > President and Chief Mapmaker
> > TopoZone.com / Maps a la carte, Inc.
> > 73 Princeton Street, Suite 305
> > North Chelmsford, MA 01863
> > ed at topozone.com
> > (978) 251-4242
> > From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> > Behalf Of Ezequias Rodrigues da Rocha
> > Sent: Thursday, July 14, 2005 12:08 PM
> > To: MAPSERVER-USERS at LISTS.UMN.EDU
> > Subject: [UMN_MAPSERVER-USERS] Res: Re: [UMN_MAPSERVER-USERS] Problem to
> > load images
> > I have no TILEINDEX and I don't know how to use it on mapserver.
> > My map file have yes 116 layers.
> > Sincerely
> > Ezequias
> > De: Ed McNierney
> > Data: 07/14/05 12:33:15
> > Assunto: Re: [UMN_MAPSERVER-USERS] Problem to load images
> > Ezequias -
> > Please always reply to the whole list, so everyone can help - thanks!
> > MapServer may be strange but it should be consistent. Do you have a
> > TILEINDEX for these 116 images or are they each specified in a separate
> > LAYER in your map file? It doesn't matter where the images are (if the
> > permissions are OK) but you should start by putting the full path to
each
> > image in either the map file LAYER block or in the TILEINDEX shapefile.
> > - Ed
> > Ed McNierney
> > ed at topozone.com
> > (978) 251-4242
> > From: Ezequias Rodrigues da Rocha [mailto:ezequias at recife.pe.gov.br]
> > Sent: Thursday, July 14, 2005 11:59 AM
> > To: Ed McNierney
> > Subject: Res: Re: [UMN_MAPSERVER-USERS] Problem to load images
> > Ed,
> > Mapsever works strange. Some file works on the cgi-bin folder others on
> > cgi-bin/raster.
> > I am working with 116 images too. I don't know if it makes any
> > difference.
> > Sincerely
> > Ezequias
> > De: Ed McNierney
> > Data: 07/14/05 11:44:53
> > Ezequias -
> > This is probably due to the paths to the data. Your error message
reports
> a
> > relative path, which depends on the "current directory" on your server.
> > It is easier to always use full pathnames (starting with a "/") to your
> > data files when you're getting started. Try putting the whole path in
> > your map file to see if that solves the problem.
> > - Ed
> > Ed McNierney
> > ed at topozone.com
> > (978) 251-4242
> > Sent: Thursday, July 14, 2005 10:40 AM
> > Subject: [UMN_MAPSERVER-USERS] Problem to load images
> > Hi list,
> > My browser reported the error above:
> > msDrawRaster(): Unable to access file. (raster/recorte_01.tif)
> > Any suggestions ?
> > all my files are -rwxrwxrwx
> > Atenciosamente (Sincerely)
> > * www.recife.pe.gov.br
> > A pior das democracias ainda é melhor do que a melhor das ditaduras
> > The worst of democracies is still better than the better of
dictatorships
> > MSN Messenger: ezequias at hotmail.com
> ____________________________________________________
> Start your day with Yahoo! - make it your home page
> http://www.yahoo.com/r/hs
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050715/49a226ba/attachment.html
