imagemap output format
Jim Donaghy jim at JIMDONAGHY.COM
Tue Jul 19 00:51:42 EDT 2005
Does anyone have an example map file working with the imagemap output
format that they would not mind sharing?
I'm using the ms4w binaries, and when I specify the imagemap format on
an otherwise working mapfile with polygons defined, it outputs the html
file with map tags but no areas defined.
Thanks in advance.
