ODBC/OVF connection
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Tue Jul 19 06:04:54 EDT 2005
Actually, OVF aka Virtual Spatial Data needs the GDAL_DATA stuff for projections AFAIK (it does not use PROJ files).
I use the following in my MAP file (MAP object) for OVF:
CONFIG GDAL_DATA /ms4w/apps/stragisweb/gdal_data
and then put the GDAL_DATA files (wkt and csv files) in that path, or choose your own path ofcourse.
GDAL_DATA could also be an environment variable.
Best regards,
Bart
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Emil Zegers <taatuut at PLANET.NL> 07/19/05 12:02pm >>>
Hello Piero,
Have you checked if the PROJ folder containing projection files is set up
and available on the production machine too?
Regards,
Emil
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Piero Cavalieri
Sent: vrijdag 15 juli 2005 16:41
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] ODBC/OVF connection
Hi all,
on my devel machine I successfully connect to a layer via ODBC/OVF
connection. Layer is a MSSQL table on Win2k.
I done the same thing on production machine (Win2003) => problems.
ArchimpXP_SIAT.ovf file:
<OGRVRTDataSource>
<OGRVRTLayer name="impianti">
<SrcDataSource>ODBC:xx/xxxx at Archimp_HEIDI</SrcDataSource>
<SrcLayer>Impianti</SrcLayer>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS>epsg:26591</LayerSRS>
<GeometryField encoding="PointFromColumns"
y="Longitudine"x="Latitudine" />
</OGRVRTLayer>
</OGRVRTDataSource>
..map file:
LAYER
GROUP i_dep_grp
CONNECTION "ArchimpXP_SIAT.ovf"
CONNECTIONTYPE OGR
DATA "impianti"
NAME "impianti"
METADATA
"wms_title" "Impianti Depurazione"
"wms_srs" "26591"
END
PROJECTION
"init=epsg:26591"
END
STATUS ON
web page:
<asp:listitem value=i_dep_grp selected=true>Depurazione</asp:listitem>
ODBC connection test:
ogrinfo ODBC:xx/xxxx at Archimp_HEIDI
returns the list of db tables, so seems ok.
Error messages when requesting the web page:
msDrawMap(): Image handling error. Failed to draw layer named 'impianti'.
msOGRFileOpen(): OGR error. Open failed for OGR connection
`Archimp_HEIDI.ovf'. Failed to import LayerSRS `epsg:26591'.
" msDrawMap(): Image handling error. Failed to draw layer named 'impianti'.
I don't understand if errors occurs during connection open or it's layer
related.
The only difference beteween development environment seems to be that in
production machine data files are in different drive (web application in
C:, data in D:; of course SHAPEPATH is set right).
Help please
P.
