ODBC/OVF connection
Emil Zegers
taatuut at PLANET.NL
Tue Jul 19 06:46:49 EDT 2005
Hello Pierro and Bart,
Good input Bart, I didn't know yet the CONFIG parameter could be used for
this. Comes in handy when youy don't want to set environment variables.
But it seems for OVF it is never necessary to use LayerSRS as long as you
put the PROJECTION parameter in the LAYER object in the map file or am I
missing something?
Regards,
Emil
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Piero Cavalieri
Sent: dinsdag 19 juli 2005 12:17
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] ODBC/OVF connection
Hello Emil,
Yes PROJ is set right. MapServer app was working fine without OGR/OVF.
I removed SRS key form ovf file, and solved the problem (I have SRS code
also in .map, so maybe it's ok so). Frank suggested me that maybe is
necessary for GDAL_DATA to point to the GDAL files like
gcs.csv and pcs.csv. I had this files on devel machine from OpenEV
installation (which set GDAL_DATA, I think), which I didn't installed on
production machine. However it seems to me that "normal" installation of
MapServer does not require separate GDAL installation, so this thing, if
true, should be written somewhere (I installed OpenEV on production
machine before deleting SRS key form ovf, but had the same error; maybe a
reboot was needed, but I wanted reboot production machine).
Thanks
P.
Emil Zegers wrote:
>Hello Piero,
>Have you checked if the PROJ folder containing projection files is set up
>and available on the production machine too?
>Regards,
>Emil
>Sent: vrijdag 15 juli 2005 16:41
>Subject: [UMN_MAPSERVER-USERS] ODBC/OVF connection
>Hi all,
>on my devel machine I successfully connect to a layer via ODBC/OVF
>connection. Layer is a MSSQL table on Win2k.
>I done the same thing on production machine (Win2003) => problems.
>ArchimpXP_SIAT.ovf file:
><OGRVRTDataSource>
> <OGRVRTLayer name="impianti">
> <SrcDataSource>ODBC:xx/xxxx at Archimp_HEIDI</SrcDataSource>
> <SrcLayer>Impianti</SrcLayer>
> <GeometryType>wkbPoint</GeometryType>
> <LayerSRS>epsg:26591</LayerSRS>
> <GeometryField encoding="PointFromColumns"
>y="Longitudine"x="Latitudine" />
> </OGRVRTLayer>
></OGRVRTDataSource>
>.map file:
>LAYER
> GROUP i_dep_grp
> CONNECTION "ArchimpXP_SIAT.ovf"
> CONNECTIONTYPE OGR
> DATA "impianti"
> NAME "impianti"
> METADATA
> "wms_title" "Impianti Depurazione"
> "wms_srs" "26591"
> END
> PROJECTION
> "init=epsg:26591"
> END
> STATUS ON
>web page:
><asp:listitem value=i_dep_grp selected=true>Depurazione</asp:listitem>
>ODBC connection test:
>ogrinfo ODBC:xx/xxxx at Archimp_HEIDI
>returns the list of db tables, so seems ok.
>Error messages when requesting the web page:
>msDrawMap(): Image handling error. Failed to draw layer named 'impianti'.
>msOGRFileOpen(): OGR error. Open failed for OGR connection
>`Archimp_HEIDI.ovf'. Failed to import LayerSRS `epsg:26591'.
>" msDrawMap(): Image handling error. Failed to draw layer named 'impianti'.
>I don't understand if errors occurs during connection open or it's layer
>related.
>The only difference beteween development environment seems to be that in
>production machine data files are in different drive (web application in
>C:, data in D:; of course SHAPEPATH is set right).
>Help please
> P.
