postgis
Stéphane RIFF
stephane.riff at CERENE.FR
Thu Jul 21 05:23:00 EDT 2005
Look in you geometry_columns table,
Does your table is in because it seems that mapserver cannot find your
geom column and the srid....
Jachym Cepicky wrote:
>Hallo,
>I have following problem with mapserver: I can not load vector file
>stored in postgis.
>I use Debain (testing), with mapserver from official repository and
>postgis from the Debian-Gis project
>(http://pkg-grass.alioth.debian.org/cgi-bin/wiki.pl).
>I stored vector shape file with help of shp2pgsql apparently without
>problems. I can acces the file e.g. usin Qgis and I can load it to
>GRASS GIS.
>However mapserver gives me quite long report, about that he is not able
>to display the map.
>msDrawMap(): Image handling error. Failed to draw layer named 'obrys'.
>prep_DB(): Query error. Error executing POSTGIS DECLARE (the actual query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT kod::text,popis::text,asbinary(force_collection(force_2d()),'NDR'),OID::text from WHERE && setSRID('BOX3D(-599514.328920447 -1159983.83918495,-581875.449556553 -1142344.95982105)'::BOX3D, find_srid('','','') )'
>Postgresql reports the error as 'ERROR: syntax error at or near "WHERE" at character 126 '
>(I posted the whole file to http://les-ejk.cz/tmp/mapserver.html)
>The mapfile part for the layer follows:
>LAYER
> NAME obrys
> TYPE polygon
> METADATA
> "title" "LH SLP Krtiny"
> END
> CONNECTIONTYPE POSTGIS
> CONNECTION "host=10.0.0.24 dbname=krtiny user=jachym"
> DATA "the_geom FROM obrys"
> CLASSITEM kod
> LABELITEM popis
> MINSCALE 50000
> CLASS
> EXPRESSION '1'
> NAME 'PUPFL "SLP Krtiny"'
> COLOR 49 135 32
> END
> CLASS
> EXPRESSION '2'
> NAME 'Sidlo'
> COLOR 190 190 190
> LABEL
> TYPE truetype
> FONT arialce
> SIZE 7
> COLOR 0 0 0
> BACKGROUNDCOLOR 255 255 255
> END
> END
>END
>In /etc/postgresql/pg_hba.conf is:
>host krtiny jachym 10.0.0.24 255.255.255.0 trust
>What to do?
>Thank you
>Jachym
