save polygons
Mehdi Kiman
oubinny at HOTMAIL.COM
Thu Jul 21 08:13:48 EDT 2005
Sorry it's a mistake.
It requires some programming, but i don't know how to do this ?
I still searach a solution...
Cordialement
>From: "Bart van den Eijnden" <BEN at Syncera-ITSolutions.NL>
>To: <oubinny at HOTMAIL.COM>,<MAPSERVER-USERS at LISTS.UMN.EDU>
>CC: <chameleon at lists.maptools.org>
>Subject: Re: [UMN_MAPSERVER-USERS] [Chameleon] save polygons
>Date: Thu, 21 Jul 2005 14:07:52 +0200
>Mehdi, did you notice you changed to the Mapserver-users list instead of
>the Chameleon list?
>It is not impossible, it requires some programming.
>Best regards,
>Bart
>Syncera IT Solutions
>Postbus 270
>2600 AG DELFT
>tel.nr.: 015-7512436
>email: BEN at Syncera-ITSolutions.nl
> >>> Mehdi Kiman <oubinny at HOTMAIL.COM> 07/21/05 02:04pm >>>
>So, it's really impossible to save ROI objects.
>my goal is only to save current user work. I must to resolve this problem
>with Oracle database or WFS/WMS or MapInfo files.
>Any solutions ?
>thanks again
>Mehdi
> >To: <oubinny at hotmail.com>
> >Subject: Re: [Chameleon] save polygons
> >Date: Thu, 21 Jul 2005 13:50:34 +0200
> >Hi,
> >what the ExtractWFS widget does is make an extraction from a layer
>already
> >in the map. Assuming you have got eg a provinces layer of your country,
>you
> >can draw an ROI in the map, eg a rectangle, and then the provinces inside
> >that rectangle can be saved into GML or a shapefile.
> >So this is only extracting existing features, not putting newly digitized
> >features into a file or database, which is what I assume you want to do.
> >Best regards,
> >Bart
> >Btw please reply to the whole list.
> >Postbus 270
> >2600 AG DELFT
> > >>> "Mehdi Kiman" <oubinny at hotmail.com> 07/21/05 01:45pm >>>
> >Hello Bart,
> >Can i use ExtractWFSData widget. Is it possible ton export the XML file
> >(GML) directly to MapInfo. Prehaps by using WFS/WMS webservices.
> >From chemeleon Help :
> >The Extract WFS Data widget allows the user to extract data based on the
> >current selected layer and ROI. Currently the following formats are
> >supported: GML Shape.
> >Thanks a lot
> >Mehdi
> > >To: <oubinny at hotmail.com>,<chameleon at lists.maptools.org>
> > >Date: Thu, 21 Jul 2005 13:12:53 +0200
> > >Chameleon is not an edit application, so you will have to add this to
> > >Chameleon yourself or hire someone to do it.
> > >One option would be getting GML out of the ROI widget (I don't think it
> >can
> > >do this at the moment), and posting it to a Geoserver WFS which
>connects
> >to
> > >Oracle. Optionally you could also probably also use the php_ogr module
>to
> > >transform the GML into Mapinfo format or Oracle Spatial.
> > >Quite a difficult task though I think, maybe even something like a
>week's
> > >work.
> > >Best regards,
> > >Bart
> > >Postbus 270
> > >2600 AG DELFT
> > > >>> "Mehdi Kiman" <oubinny at hotmail.com> 07/21/05 12:56pm >>>
> > >Hello,
> > >I use chameleon for making my application.
> > >I wish to save my drawing operations in a mapInfo file (.TAB) or in
> >Oracle
> > >Database.
> > >For exemple, i draw a polygon in my map with chameleon ROI widget and
> >save
> > >it.
> > >Can you give me some help please ?
> > >Thanks
> > >Mehdi
> > >_______________________________________________
> > >Chameleon mailing list
> > >Chameleon at lists.maptools.org
> > >http://lists.maptools.org/mailman/listinfo/chameleon
