Problems with gdal
Frederico Lucca
fredlucca at GMAIL.COM
Thu Jul 21 19:00:09 EDT 2005
On 7/21/05, Frank Warmerdam <fwarmerdam at gmail.com> wrote:
> On 7/21/05, Frederico Lucca <fredlucca at gmail.com> wrote:
> > Hello Frank,
> > Well, I translate some TABs to SHPs using org2ogr.
> > Then I return to my tests and loopings, and I get this error.
> > C [libpthread.so.0+0x6a12] __pthread_mutex_lock+0x12
> > What can I do now?
> > I call a jsp page which create a unique map, I call this application
> > from another with a looping - for 1 to 100. Then, I put 3 or 4 of
> > this applications running at same time. And I get the error. When I
> > was using TABs I get the error (with gdal) with 2 applications running
> > at same time.
> Frederico,
> This is using mapserver and shapefiles, without using CONNECTIONTYPE
> OGR, right?
> I am not sure why you are running into problems. It isn't a configuration
> I can easily reproduce myself.
> Sorry,
Hello Frank,
Yes, I'm just using DATA.
I don't know, I'm just testing the application to put the server in production.
I need to stress the software and hardware, but I found some problems.
Well, this is the configuration in my PC, I will install mapserver
into a really great server. I will try this and see what I get.
It's not a big software, I don't use threads. I'm juts simulating the
request from the client.
There is something you want to know about the application? Could help
you to help me.
Well, thanks a lot for everything.
Best Regards,
Fred
"Everything under the sun is in tune
But the sun is eclipsed by the moon"
