Embedding connection xml in mapfile
David Shorthouse
dps1 at UALBERTA.CA
Fri Jul 22 16:07:18 EDT 2005
Hello folks,
I am making use of an OGR virtual data ODBC connection to SQL Server
2000. I have a separate xml file to handle the query (actually it's a call
to a stored procedure). Ideally, I'd like to pass a variable from the
mapfile to this query and make use of a parameterized stored procedure. I
discovered that one can embed the xml within the mapfile, which should allow
this. I can format the separate xml file for the call to the stored
procedure to include a parameter and it works great. In this case however, I
have no hope of passing a variable as the parameter. The xml must be in the
map file. When I attempt to do this however, the layer just doesn't generate
because the connection chokes.
Here's what I have in the separate xml to handle the connection:
<OGRVRTDataSource>
<OGRVRTLayer name="SpiderData">
<SrcDataSource>ODBC:[connectionhere]</SrcDataSource>
<SrcLayer>SpeciesMapServer</SrcLayer>
<SrcSQL>{CALL SpeciesMapServer}</SrcSQL>
<GeometryType>wkbPoint</GeometryType>
<LayerSRS>WGS84</LayerSRS>
<GeometryField encoding="PointFromColumns" x="UTMx" y="UTMy"/>
</OGRVRTLayer>
</OGRVRTDataSource>
I can change the stored procedure to include a parameter and the SrcSQL
above to {CALL SpeciesMapServer ('parameter')} and it works great. But of
course, this doesn't permit passing a variable such as %parameter% from the
mapfile.
So, here is what I tried in the mapfile:
LAYER
NAME spiders
CONNECTIONTYPE OGR
CONNECTION '<OGRVRTDataSource>
<SrcSQL>{CALL SpeciesMapServer ('%FullName%')}</SrcSQL>
</OGRVRTLayer>
</OGRVRTDataSource>'
DATA SpiderData
STATUS DEFAULT
TYPE POINT
etc.
It's the SrcSQL above that chokes. Notice the required, either single or
double quote around %FullName%. This is obviously results in a truncation of
the remainder of the connection string in the case of a single quote or
failure of a layer being returned in the case of a double quote.
Anyone know how to get this to work? Is it just not possible to pass a
mapfile variable to a stored procedure's parameter?
Thanks,
Dave
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050722/d735f888/attachment.html
