problem with line layers
Steve Lime
steve.lime at DNR.STATE.MN.US
Tue Jul 26 13:31:17 EDT 2005
It's the STATUS values. The CGI program turns all layers that are not "STATUS DEFAULT"
off and then requires you to explicitly request layers. MapScript-based applications
will usually respect the STATUS value set in the mapfile.
The solution? Either use STATUS DEFAULT or explicitly request those layers you want in
your call to the CGI application (i.e. &layer=calles&layer=puntos).
Steve
>>> Sergio Lopez <sergiodlopez at YAHOO.COM> 07/26/05 12:26 PM >>>
Hi all:
I have a problem with line layers. I use the following map file, and I
call it using http://localhost/cgi-bin/mapas/lp.map&mode=map, but the line
layers are not shown, just the background. But if I use this map file with
mapedit or gmap everithing´s ok. what am I doing wrong?
MAP
NAME "lplineas"
STATUS ON
EXTENT 5656000 6090000 5707000 6149000
SIZE 300 300
SHAPEPATH "./data"
SYMBOLSET "./etc/symbols.sym"
FONTSET "./etc/fonts.txt"
IMAGETYPE JPEG
IMAGECOLOR 100 150 200
UNITS METERS
#----OBJETO WEB----------------------------------------------------------
WEB
IMAGEPATH "/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
END
#----FORMATO DE SALIDA---------------------------------------------------
OUTPUTFORMAT
NAME "JPG"
MIMETYPE "image/jpeg"
DRIVER "GD/JPEG"
EXTENSION "jpg"
IMAGEMODE RGB
TRANSPARENT OFF
FORMATOPTION "QUALITY=80"
END
#----LAYER CALLES--------------------------------------------------------
LAYER
#-------COMIENZA LAYER
NAME "Calles"
#GROUP "vias"
STATUS ON
DATA "./data/ejes"
TYPE POLYGON
#MINSCALE 25000
TOLERANCE 10
TOLERANCEUNITS PIXELS
CLASS
NAME "calle"
#TEMPLATE "ttt_query.html"
STYLE
SYMBOL 13
COLOR 103 106 107
SIZE 3
MINSIZE 3
MAXSIZE 25
#MINSIZE 1
#MAXSIZE 100
ANTIALIAS TRUE
END
END
END
LAYER
NAME "puntos"
STATUS ON
DATA "./data/cajeros"
TYPE POINT
UNITS METERS
CLASS
NAME "fff"
STYLE
SYMBOL 7
COLOR 172 0 0
SIZE 1
MINSIZE 3
MAXSIZE 25
END
END
END
#---------TERMINA LAYER
END
