SLD pointsymbolizer externalgraphic trouble
Pagurek,Debbie [NCR] Debbie.Pagurek at EC.GC.CA
Thu Jul 28 13:57:40 EDT 2005
Latest update is that I totally re-installed MS4W version 1.2.1
Same problem exists for version 4.6.
However, it WORKS with the 4.4 version in the package. SLD with pointsymbolizer using external graphic works with 4.4.
Bug?
How should I proceed? What should I test?
Debbie
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Pagurek,Debbie [NCR]
Sent: Thursday, July 28, 2005 12:02 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] SLD pointsymbolizer externalgraphic trouble
Well, I've confirmed that my approach for getting charts on a map using SLD, pointsymbolizer and externalgraphics will work because I tested it against DMSolutions server with my own SLD and graph: http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?version=1.1.1&service=wms&request=getmap&layers=prov_bound,popplace&sld=http://devgeo.cciw.ca/ecesdi/sldpoint4.xml
However, on my own installations of mapserver, I can't get this to work. I get the provincial boundaries with no point layer at all.
I am looking in my apache error log and I see:
[Thu Jul 28 11:58:12 2005] [error] [client 127.0.0.1] msDrawMap(): Layer 5 (prov_bound), 0.015s\r [Thu Jul 28 11:58:12 2005] [error] [client 127.0.0.1] msDrawMap(): Layer 9 (popplace), 0.016s\r [Thu Jul 28 11:58:12 2005] [error] [client 127.0.0.1] msDrawMap(): Drawing Label Cache, 0.000s\r [Thu Jul 28 11:58:12 2005] [error] [client 127.0.0.1] msDrawMap() total time: 0.031s\r
This error occurs even just with only the prov_bound layer, no SLD. So - is it time for me to re-install mapserver 4.6 on my machine? Any other possible solutions?
Debbie
Sent: Wednesday, July 27, 2005 12:07 PM
Assefa,
I'm quite sure that mapserver is finding the appropriate temp directory to write to because I got an SLD with polygonsymbolizer and external graphic to work just fine, and an image called H1.gif appears in that temp directory and my map is symbolized properly.
However, I still can't get the same thing to work with a pointsymbolizer.
My intention is to try to get little graphs on a map using SLD, pointsymbolizer and filters so that a layer that has centroids of provinces for instance can have a different graph at the centre of each province.
What do you and others think of that approach for getting graphs on a map?
Can anyone suggest anything else?
Anyway, still need to get a point symbolizer working with external graphics. Attached is the sld that I'm using for points... I'm at a total loss. An SLD for polygons and external graphics works fine.
Debbie
From: Yewondwossen Assefa [mailto:assefa at dmsolutions.ca]
Sent: Wednesday, July 27, 2005 9:35 AM
To: Pagurek,Debbie [NCR]
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Pagurek,Debbie [NCR] wrote:
> My maps returns fine with a simple getmap request.
> The tmp directory is set to c:/ms4w/tmp/ms_tmp
> Is there a way to check that mapserver is writing to that directory?
> Ie if I use mode=map, should it leave a temporary file there? Mode=map
> is giving me a map, but isn't leaving a file in that temp directory.
  You can use mode=browse and that should create files in the tmp dir.
You need to set the template in the web object :
   WEB
   TEMPLATE  "template.html"
  template.html should exist but can be empy or have something like this
<input type="image" name="img" src="[img]">
Later,
> Debbie
> On Behalf Of Yewondwossen Assefa
> Sent: Tuesday, July 26, 2005 4:46 PM
> Debbie,
>>Assefa,
>>Are nightly builds available for Windows binaries?
>>I changed my sld to show GIF instead of image/gif but it's still not
>>working.
> I am not sure why It is not working for you. I basically took your
> mapfile and change few paths to adapt  to my settings. The map file
> points to the gmap-ms40 data. The sld I used is basically yours (I
> don't think I modified anything). I have attached both files.
> There are no nightly builds although I can put a mapserver 4.7 cvs
> version on maptools if you need.
>>I realized in the examples I sent earlier that my sld didn't contain a
>>Geometry tag. What should this field "property name" contain? A name
>>of a field in the shapefile? the word "msGeometry"?
> Should not matter. It is not used.
>>Can you think of anything else I can check on my system to test this?
>>Am I missing something important in my mapfile? I've tried using my
>>own mapfile and also the gmap75_wms.map file that comes with ms4w.
>>At this point I'm just not getting any sld with an external graphic to
>>work.  Will keep trying.
>>Debbie
>   Is your map returned with a somple getmap rquest without an sld ?
>   I am also assuming that the temporaary directory and path are set
> properly in the map file (since the graphic is downloaded and copied
> in that directory)
>>Debbie,
>>  I have tested your sld with local data and the only "problem" I
>>found was that the format used is <Format>image/gif</Format> instead
>>of <Format>gif</Format>.  I have rechcked the sld specs and it
>>specifies that the format should be of MIME type so your sld should be
>>valid. I have corrected the test to test for GIF or image/gif (as well
>>as PNG and image/png). (related bug is
>>http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1430).
>>  If possible use the latest version from cvs or until you get a new
>>build you can use GIF as the value of the format.
>>  Later,
>>>I am having trouble with an SLD that should put an externalgraphic at
>>>a point. I am getting a blank map and when I do a view source I am
>>>seeing Gobbldygook: GIF87aXÿ€ ...etc (this happens if I set
>>>imagetype GIF or PNG), and also if I don't set IMAGETYPE at all. An
>>>SLD that uses an external graphic for a polygon layer works fine.
>>>I am including the sld file and my mapfile as attachments, and the
>>>following is the URL I'm using.
>>>http://localhost/cgi-bin/mapserv.exe?map=c:\ms4w\apps\chameleon-2.2\c
>>>e
>>>si\map\pix.map&version=1.1.1&service=wms&request=getmap&layers=poppla
>>>c
>>>e&sld=http://localhost/chameleon/cesi/sldtest.xml
>>>I'm on Windows.
>>>MapServer version 4.6.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>>>OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
>>>SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
>>>SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER INPUT=JPEG INPUT=POSTGIS
>>>INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
>>>Anybody have any ideas? Is this a bug?
>>>D. Pagurek
>>><?xml version="1.0" encoding="utf-8" standalone="no" ?>
>>><StyledLayerDescriptor version="1.0.0"
>>>xmlns="http://www.opengis.net/sld"
>>>xmlns:ogc="http://www.opengis.net/ogc"
>>>xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>>xsi:schemaLocation="http://www.opengis.net/sld http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd">
>>><Name>dp_generated_sld</Name>
>>><Title>test sld for external graphic</Title>
>>><Abstract>test</Abstract>
>>><NamedLayer>
>>>	<Name>popplace</Name>
>>>	<UserStyle>
>>>	<Name>Cities</Name>
>>>	<Title>Cities</Title>
>>>	<IsDefault>1</IsDefault>
>>>	<FeatureTypeStyle>
>>>	<Rule>
>>>		<PointSymbolizer>
>>>			<Graphic>
>>>			<ExternalGraphic>
>>>			<OnlineResource xlink:type="simple"	xlink:href="http://www.oreilly.com/animals/parrot.gif" />
>>>			</ExternalGraphic>
>>>			<Size>44</Size>
>>>			</Graphic>
>>>		</PointSymbolizer>
>>>	</Rule>
>>>	</FeatureTypeStyle>
>>>	</UserStyle>
>>></NamedLayer>
>>></StyledLayerDescriptor>
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
