mapserver tif projections
Ethan Alpert
ealpert at DIGITALGLOBE.COM
Thu Jul 28 15:55:28 EDT 2005
You should be using the units of the laea projection rather than decimal
degrees to set the EXTENT.
It's very difficult to know from a lat/long box what the output of the
projection will be. It's best to use the units of the projected
coordinate system.
-e
EXTENT -85 32 -75 38
Should the extent be in meters? Isn't putting the projection in
the layer supposed to make that transformation? All of my other layers
just use lat/lon not LAEA and they work fine. So, I'm mixing two types
of coordinates here, and it's still a mystery to me as far as how this
is supposed to work.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050728/2a8e427f/attachment.html
