Labeling Question
Stephen Woodbridge woodbri at SWOODBRIDGE.COM
Fri Jul 29 08:21:52 EDT 2005
magnus gmail wrote:
> Hi,
> First question:
> Does mapserver *"label collision mediation" *work per layer or is it
> done accross all the layers in the map?
It is done across all labels the are put in the label cache. This
basically means Yes across all layers in the map. The priority is based
on last into the cache is first out.
The idea being that as you draw layers from the top of the mapfile to
the bottom of the mapfile you are imaging the most important stuff last
on the upper most visual layer of the map. These last layers being most
important get their labels rendered first. As more and more labels get
draw there is less and less free space for labels from the lower (less
important layers so they tend to get bumped off the map.
You a little control over this if you are willing to split rendering and
annotation of a layer into two layers at the cost of scanning that data
twice. Then you can place the annotation layer higher in the layer stack
to get higher priority.
-Steve W.
