WFS and mapserver-4.6.0-beta3
Steve Lime
steve.lime at DNR.STATE.MN.US
Thu Jun 2 17:09:24 EDT 2005
Bart is correct, you now have to explicitly publish attributes. WFS is still undergoing a last bit of tweaking to give you lot's of control with schema and instance document format. GML3 will be supported as well. We need to get the documentation updated before the release candidate.
Steve
>>> Bart van den Eijnden <bartvde at XS4ALL.NL> 06/02/05 1:41 PM >>>
you need to use the new METADATA at the LAYER level:
METADATA
gml_include_items "all"
END
Best regards,
Bart
On Thu, 02 Jun 2005 19:33:37 +0200, Michel Garand <garand at ODRAGIS.ORG>
wrote:
> Greetings!
> I just downloaded the mapserver-4.6.0-beta3 and now testing WMS and WFS
> capabilities.
> Here is my problem:
> With mapserver 4.4.2 - WFS seems to work ok
> http://odragis.org/cgi-bin/slubfurt2wms?
> SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=Nodes
> with the result:
> <schema targetNamespace="http://www.ttt.org/myns"
> elementFormDefault="qualified" version="0.1">
> <import namespace="http://www.opengis.net/gml"
> schemaLocation="http://schemas.opengeospatial.net/gml/2.1.2/feature.xsd"/>
> <element name="Nodes" type="myns:Nodes_Type"
> substitutionGroup="gml:_Feature"/>
> <complexType name="Nodes_Type">
> <complexContent>
> <extension base="gml:AbstractFeatureType">
> <sequence>
> <element ref="gml:pointProperty" minOccurs="0"/>
> <element name="oid" type="string"/>
> <element name="elem_id" type="string"/>
> <element name="name" type="string"/>
> <element name="rep_index" type="string"/>
> </sequence>
> </extension>
> </complexContent>
> </complexType>
> </schema>
> and with mapserver-4.6.0-beta3 - WFS seems not to work properly:
> http://odragis.org/cgi-bin/slubfurtwms?
> with the result:
> <element name="Nodes" type="myns:NodesType"
> <complexType name="NodesType">
> <complexContent>
> <sequence>
> <element name="geometry" type="gml:GeometryPropertyType" minOccurs="0"
> maxOccurs="1"/>
> </sequence>
> </extension>
> </complexContent>
> </complexType>
> </schema>
> The new version of mapserver doesn't seem to spit out the
> <sequence>
> </sequence>
> as in the mapserver 4.4.2 version.
> Any advice?
> Thanks in advance for any assistance
> Michel
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
