Shortest route solution
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Mon Jun 6 06:38:40 EDT 2005
It should be doable, for the algorithm check out
http://en.wikipedia.org/wiki/Dijkstra%27s_algorithm
-Steve W.
http://imaptools.com
Janeks Kamerovskis wrote:
> What if the optimal route solution is done in php with mapscript?
> (in cases when route shape file are not too big ( ~ 5 mb?) )
> Could somebody tried something similar?
> brgds
> Janeks
>>-----Original Message-----
>>From: UMN MapServer Users List
>>[mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On Behalf Of Stephen Woodbridge
>>Sent: Friday, June 03, 2005 4:29 PM
>>To: MAPSERVER-USERS at LISTS.UMN.EDU
>>Subject: Re: [UMN_MAPSERVER-USERS] Shortest route solution
>>This has been discussed in the archives search for "router"
>>In general, this should not be a mapserver function because, the data
>>(or organization of the data) required is not what mapserver needs or
>>vica versa. The best (better?) way to do this is to create a separate
>>application the computes the route and returns an xml document or a
>>couple of files with a unique name. Then use mapscript to integrate the
>>results with a map.
>>I have done this and have a demo at http://imaptools.com/demos1/?tab=2
>>The router is C code and creates a filename.shp and filename.txt as
>>results. the PHP code then takes the shapefile and adds it to a layer
>>already in the mapfile and the driving directions go into the
>>filename.txt and they are read and displayed under the make.
>>The biggest issue is that you need data that is good for routing and in
>>most cases that means commercial data which is very expensive.
>>This worked for me, hope it helps you get started.
>>-Steve W.
>>Gambin Dejan wrote:
>>>Hi,
>>>Did anybody implement the shortest route algorithm to mapserver and what
>>>are the experiences/suggestions? I would like to be able to find a
>>>shortest route between two points on my MapServer map and highlight it
>>>somehow. I found a conference document about grass server that should be
>>>able to do so using php extension on client side (the client can be
>>>mapserver). Does it exist or is just in future plan?
>>>I would appreciate any suggestions on this field
>>>thanks
>>>dejan
