Mapped Network Drives - Win Xp
Ed McNierney ed at TOPOZONE.COM
Thu Jun 9 10:32:49 EDT 2005
Jim -
Remember that when MapServer is run as a CGI binary under IIS, it is
running in the user context configured for your Web server/site.  It's
NOT running as "you", so "your" M:\ drive mapping may be completely
ignored.  In fact, the default IUSR_<machinename> account is configured
to not have access to any network resources at all, for security
reasons.
Network drive mappings are very tricky to manage.  I have not tried in a
long while, but if I'm not mistaken you may have more success with UNC
names (\\SERVER\SHARE\FILENAME) to point to those resources.  That will
avoid the drive mapping issue, but the user context being used will
still need to have the correct access permissions to use the resource.
	- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Jim Bilsborough
Sent: Wednesday, June 08, 2005 11:31 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] Mapped Network Drives - Win Xp
I'm a newbie here.  last week I installed Windows binaries (ms4w) on a
Win2K machine and followed the instructions and all worked perfect.
Where the instructions recommended installing below the root directory
of a drive, I created a folder called "Mapserver" and used "Map Network
Drive"
to refer to that folder as my M:\ drive (m=mapserver) - like I said, it
worked great - both on that machine and other computers on the network.
This week I ported my work in progress to an computer running Win XP
Professional (SP2), and guess what - it no longer works.  I've
discovered that If I move my MS4W folder below the C:/ root it works
fine, but even if I map the whole of the C:\ drive as drive M:\, my
client pages can never find references to .map files, etc under the M:
drive - it only accepts local C:\ drive references.
I guess this is probably more of an XP issue, than anything to do with
mapserver, ms4w, etc - but I'm hoping someone here has expereinces the
same and knows the solution.
TIA
Jim
