wind barbs
Nate Reed
nate at SEASTAR.JPL.NASA.GOV
Fri Jun 10 17:38:26 EDT 2005
Hello,
I'm hoping I can get some pointers on drawing windbarbs in PHP Mapscript
from this list.
Currently, I'm able to draw a point on my map by using some code
that I found on the list archive and various other places on the net.
However, the character does not appear to be correct (I've attached the
map - it's that small black speck at -120,30).
I have downloaded the ESRIWeather font and added it to my fontlist, and
aliased it with 'weather'.
The layer definition looks like this:
LAYER
NAME tt_symbol
STATUS ON
TYPE POINT
CLASS
NAME "0"
STYLE
END
LABEL
FORCE TRUE
TYPE TRUETYPE
FONT weather
SIZE large
ANTIALIAS true
OUTLINECOLOR 0 0 0
COLOR 0 0 0
POSITION UC
ANGLE 0
BUFFER 0
PARTIALS TRUE
END
END
END
The code looks like this:
$this->image = $this->map->draw();
$layer = $this->map->getLayerByName('tt_symbol');
$point = ms_newPointObj();
$point->setXY(-120,30);
$point->draw($this->map,$layer,$this->image,0,"ã");
$this->map->drawLabelCache($this->image);
I could use some help to improve the output. One curious thing is if I
remove the Style object from the Map file the character does not appear at
all. This suggests that perhaps something else is required in the layer
or style objects?
Thanks,
Nate
Nate Reed
Physical Oceanography DAAC
Jet Propulsion Lab / Raytheon ITSS
(626)744-5528 nate at seastar.jpl.nasa.gov
Type: image/png
Desc: map
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050610/14f90391/1118439316193731.png
