EPSG code for...
Christopher R. Thorne christhorne at SYMPATICO.CA
Sat Jun 11 12:53:08 EDT 2005
Hello Dean,
Dean C. Mikkelsen wrote:
> Hi Chris,
> Take a look at the following web-page.
> I am leaning towards a problem now in defining which State Plane
> Co-ordinate System is being used. i.e. one of the ones we are using is
> wrong - we may actually be north or south of the current one. Now the
> trick is to determine which one. A note to other readers epsg:4326 is
> WGS84.
> Did you try reprojecting the NAD27 Layer with the NAD83 definition?
Yes I did that and the layers switched positions.
Or
> with epsg:4326? What happens?
with setting the projection to the lat/long layers, they are not found
in outer space, not within the world extent.
> http://www.wadetrim.com/resources/articles/sblocks.htm
Thanks for the good reference. The reason why I got into this situation
was because I am four steps removed from the data provider. I only
managed to get the information that you already know and I was hoping
the information was correct. The other problem was that I was not sure
how to identify the issues, confidently. If not I will definitely push
for more information.
Cheers and thanks again,
Chris
Christopher R. Thorne, GIS Specialist
christhorne at sympatico.ca
Tel:(613)523-6593, Ottawa ON Canada
