MrSid questions
Christopher R. Thorne christhorne at SYMPATICO.CA
Tue Jun 14 13:22:37 EDT 2005
Hello List,
I got the 1.2.6 version of the /gdalpulgins/gdal_mrsid.dll and
/cgi-bin/lti_dsdk_dll.dll in the correct spots in ms4w and verified
httpd.conf file had the correct setting  GDAL_DATA "/ms4w/gdaldata") and
  GDAL_DRIVER_PATH "/ms4w".
I am not sure if this is correct. Either way it did not work. I used the
following layer definition:
#  LAYER
#    NAME "raster"
#    STATUS ON
#    DATA "1footpixels.sid"
#    TYPE RASTER
#  END
I even tried version 1.2.5, but still same result.
Any tips?
Chris
Frank Warmerdam wrote:
> Chris,
> I thnk if you dig into the MS4W mailing list archive you can find
> an email from me about about MrSID support.  Basically I build
> a MrSID "plugin" for MS4W's version of GDAL that should allow
> you to use MrSID files.  You will still need to download the MrSID
> DLLs from the Lizardtech web site yourself.
> Let me know if you run into problems.
> Best regards,
Christopher R. Thorne, GIS Specialist
christhorne at sympatico.ca
Tel:(613)523-6593, Ottawa ON Canada
