Browse mode in Tutorial
Justin Fail
justin.fail at GMAIL.COM
Tue Jun 14 19:44:02 EDT 2005
Hi all,
I'm new to using MapServer and have run into a snag when attempting
the tutorials from example number 1-9.
It involves when using the browse mode for the map inside a form.
I get the following message when clicking inside my (empty) browse map form:
msEvalRegex(): Regular expression error. String ([map]) failed expression test.
My static map appears fine, so I assume that somewhere its failing to
update the tags inside the form.
The only thing that I can think of is that my IMAGEPATH and IMAGEURL
settings are not correct, but I have tried every alternative option
for these without any sucess.
Here are my current WEB settings:
WEB
TEMPLATE 'example1-9.html'
IMAGEPATH 'C:\Program Files\Apache Group\Apache2\htdocs\tmp\'
IMAGEURL 'http://localhost/tmp/'
END
Obviously, I'm running a windows version using Apache.
Any other ideas?
Cheers,
Justin.
