ogr2ogr problem!
Gabriel Cloutier gabriel.cloutier at RNCAN.GC.CA
Wed Jun 15 11:33:35 EDT 2005
 I have a problem with this tool under Unix.
When I execute:
ogr2ogr -f "ESRI Shapefile" -select
layer BARRAGE_1_012B08.shp -a_srs EPSG:42304 -skipfailures
I have this error:
ERROR 6: EPSG PCS/GCS code 42304 not found in EPSG support files.  Is this a
EPSG coordinate system?
Failed to process SRS definition: EPSG:42304
My GDAL_DATA is correctly set on my /data directory.
I took the data directory of a FWTools Windows installation do you think
that can be the problem ?
If I use EPSG:4326 my command work fine.
The problem seems to be when the tool try to access to the the file
This file contain the definition of my projection (EPSG:42304)
Thank you for your help!
Gabriel Cloutier
Natural Resources Canada
Centre for Topographic Information
Web Services Team
2144 King West Street, s. 010
Sherbrooke, Quebec  J1J 2E8
E-Mail:  Gabriel.Cloutier at NRCan.gc.ca
Tel:  (819) 564-5600 #295
Fax:  (819) 564-5698
