file size issue
Jerl Simpson
jerl.simpso at GMAIL.COM
Thu Jun 16 09:41:02 EDT 2005
Hello,
I have a particular issue with file size limits. I have a layer (2
actually) that contains roads classified as "Local Roads" throughout
the entire contiguous 48 US states. I had to split this up into 2
files due to filesize limits. My apache server keeps throwing errors
that say "[notice] child pid 12855 exit signal File size limit
exceeded (25)". So I would like to add these to a MySQL table and
pull the data from there.
I am running into two problems.
1. I used one of my very small shape files to setup an SQL connection
to grab the data. When I modified my .map file I now get an internal
server error. Which simply means some data was spit out before HTTP
headers terminated. I have a log file and DEBUG ON set in my map file
and nothing gets placed in the file. Is there any documentation that
tells one how to build the queries? I can't seem to find them.
2. The shape file I have for Local Roads is 1.2Gb. And the perl
Shapelib module reads the entire shape file into an array. Well, I
don't have 1.2Gb of memory on my machine available so when I run
"shp2mysql.pl LocalRoad" the program terminates with the error
"Terminated". I looked at the documentation and I don't see a way to
just grab records out of the file. I tried get_record() but that
threw error messages.
I have a tiled this file into 100 smaller files the largest of which
is 63Mb. I could write a script to run to shp2mysql.pl on each file.
I would rather have a program to operate on the original file though,
as I'm afraid I'll end up with 100 seperate tables with the same data.
Or I would need to modify the script to foce them all into the same
table.
I appreciate any help,
jerl
