Catching error of getShape - php_mapscript
Jacob Delfos
jacob.delfos at MAUNSELL.COM
Thu Jun 16 21:35:55 EDT 2005
Hi Julien,
Thanks for your suggestion. I have tried it, but it didn't work. I have tried using my own error handler (with set_error_handler), but even if I do that, my php log says:
[17-Jun-2005 09:23:21] PHP Fatal error: [MapServer Error]: msLayerGetShape(): Invalid feature id.
I also get this when using the mapserver error object. I guess it's because the getShape function generates a fatal error, which in php will always result in script termination.
I guess my problem is using php_mapscript_44 and php4. If I used php 5 I could use a "try catch" statement....
Regards,
Jacob
-----Original Message-----
From: Julien-Samuel Lacroix [mailto:jlacroix at dmsolutions.ca]
Sent: 16 June 2005 23:00
To: Jacob Delfos
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Catching error of getShape - php_mapscript
With Mapscript there's the errorObj object that can do exactly what you
want I think. There's an example of how to use it in the doc.
http://mapserver.gis.umn.edu/doc44/phpmapscript-class-guide.html#errorobj
Julien
On 06/16/2005 03:04 AM, Jacob Delfos wrote:
> Hi all,
> Can anyone tell me if there is a way to catch the error that getShape
> throws if you request a shape that is out of range?
> Reason is I'm trying to iterate through a layer. At this stage, I need
> to use an object count to make the loop stop. Getting an object count
> either requires me to use the shpfileobj->numshapes variable (which
> obviously only works on shapefiles), or doing a query (which would only
> work on layers with templates, which would need a reprojected rectangle,
> uses overhead, etc..).
> Would it be possible to make getShape return MS_FAILURE if the object is
> out of range, or throw a warning that can be caught using '@' error
> suppression? That way one could iterate through a whole layer without
> needing a layer count.
> Regards,
> Jacob
> *JACOB DELFOS
> SPATIAL INFORMATION ANALYST
> *Maunsell Australia Pty Ltd
> 629 Newcastle Street, Leederville, WA 6007
> PO Box 81, Leederville, WA 6902
> Western Australia
> ABN 20 093 846 925
> Tel + 61 8 9281 6185
> Fax + 61 8 9281 6297
> _jacob.delfos at maunsell.com_
Julien-Samuel Lacroix jlacroix at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050617/be6ebbc9/attachment.html
