Running different versions on Windows simultaneously
Jacob Delfos jacob.delfos at MAUNSELL.COM
Sat Jun 18 03:11:44 EDT 2005
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Content-Transfer-Encoding: 8bit
Bernd,
Thanks for your suggestions. I guess it would be possible, but to have
to change all extensions (and links) will be quite an administration.
And the problem with running on a different port is that some companies
(such as mine) tend to block all ports that are not standard....
regards,
Jacob
-----Original Message-----
To: Jacob Delfos; MAPSERVER-USERS at LISTS.UMN.EDU
Sent: 6/17/2005 6:24 PM
Subject: Re: [UMN_MAPSERVER-USERS] Running different versions on Windows
simultaneously
Hey jacob,
First of all you do not nee to put your DLLs in windows System
directory.
You can put them to the root of php directory where you can find
php.exe.
So your hole system can work without setting the PATH variables.
Two differents ways to resolve your problem (testing different versions
of mapscript ):
1.
You ca use different php directories (for exemple php4ms44 and php4ms46)
After that you use different php file extensions ( for exemple
.php4ms44 php4ms46)
In your configuration file of your webserver you need to associate the
file extension name to the right php.exe
in apache configuration file httpd.conf :
ScriptAlias /php4ms44/ "c:/yourpathtophp/php4ms44/"
   AddType application/x-httpd-php .php4ms44
   Action application/x-httpd-php "/php4ms44/php.exe"
ScriptAlias /php4ms46/ "c:/yourpathtophp/php4ms46/"
   AddType application/x-httpd-php .php4ms46
   Action application/x-httpd-php "/php4ms46/php.exe"
2.
An other way is to use seperate web servers on differents ports (80; 81;
82; for exemple  http://localhost:90 <http://localhost:90>
http://yourdomain:97 <http://yourdomain:97> ) on the same domain witch
use differents php.exe
In this case you do not need different php file extension names.
Hope it helps,
Bernd
Bernd Deckert
01MAP - la carte vecteur d'information
35, allée d'Irlande
34080 Montpellier
04.67.45.60.27
06.83.39.16.62
http://www.01map.com <http://www.01map.com>
----- Original Message -----
From: Jacob Delfos <mailto:jacob.delfos at MAUNSELL.COM>
To: MAPSERVER-USERS at LISTS.UMN.EDU <mailto:MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Friday, June 17, 2005 10:52 AM
Subject: [UMN_MAPSERVER-USERS] Running different versions on Windows
simultaneously
Hi All,
I am about to set up a new internal server for running mapserver-based
sites, and I am trying to do it such that I can run different versions
of php_mapscript (and mapserver).
The problem I am running into is that certain versions of the dll are
compiled against certain of its dependent dll's. For example,
php_mapscript_46 works fine with the gdal12.dll that comes with it, but
not with the dll I compiled for php_mapscript_44. And one gdal12.dll
will only work with the ecw dll's it was compiled with.
I have tried keeping them in separate directories. This nearly worked,
but for some reason gdal12.dll MUST sit in the windows System directory
(even if you set up your paths correctly). I cannot just sit with the
php_mapscript dll. The same goes for some other dll's. Even if the
dependency walker says that all is fine, the website will not run unless
it sits in system32.
Has anyone been able to implement this more successfully? Any tips?
Regards,
Jacob
JACOB DELFOS
SPATIAL INFORMATION ANALYST
Maunsell Australia Pty Ltd
629 Newcastle Street, Leederville, WA 6007
PO Box 81, Leederville, WA 6902
Western Australia
ABN 20 093 846 925
Tel     + 61 8 9281 6185
Fax    + 61 8 9281 6297
jacob.delfos at maunsell.com <mailto:jacob.delfos at maunsell.com>
