mapscript/java errors
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Mon Jun 20 06:56:40 EDT 2005
you should find a libmapscript.so in mapscript/java.
Try to run the tests with
make test
Regards,
Umberto
On 6/20/05, orkun <temiz at deprem.gov.tr> wrote:
> Umberto Nicoletti wrote:
> >You need to compile mapserver first and then cd to mapscript/java. You
> >should try to run
> >make interface
> >before running make in mapscript/java as it will generate/update the
> >swig-generated interface files. You need a very recent version of swig
> >to run make interface.
> >I have not tried mapserver 4.6 yet so there might be unresolved issues
> >with java maspcript that I am not aware of.
> >HTH,
> >Umberto
> >>thank you for your interest:
> >>- linux debian testing
> >>- mapserver-4.6.0-beta1
> >>- I changed mapscript/java then entered make and the nightmare started.
> >>here is my config
> >>--with-proj \
> >>--with-threads \
> >>--with-ogr \
> >>--with-gd=/usr/local/gd-2.0.33 \
> >>--with-gdal=/usr/local/bin/gdal-config \
> >>--with-png \
> >>--with-php=/usr/local/php-5.0.4/ \
> >>--with-java=/usr/local/jdk1.5.0_03/
> >>I have been using phpmapscript. But I am curious about java.
> >>Can you say that developing and using mapserver with java is better
> >> than php ?
> >>regards
> >>______________________________________
> >>XamimeLT - installed on mailserver for domain @deprem.gov.tr
> >>Queries to: postmaster at deprem.gov.tr
> >>The views and opinions expressed in this e-mail message are the sender's own
> >>and do not necessarily represent the views and the opinions of Earthquake Research Dept.
> >>of General Directorate of Disaster Affairs.
> >>Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
> >>B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
> hello
> with make interface, it produced so many *.java files in
> ../mapscript/java/edu/umn/gis/mapscript/ directory.
> not a compiled library as in phpmapscript.so ?
> Is there anything as next step ?
> regards
> Ahmet
