Musmap 0.9.0-beta
Mathieu PARENT
math.parent at GMAIL.COM
Mon Jun 20 12:21:05 EDT 2005
The musmap demo is online: http://mathieu.parent.hd.free.fr/musmap/latest/
2005/6/20, Mathieu PARENT <math.parent at gmail.com>:
> Musmap 0.9 is pending now, just some testing is needed to find bugs.
> You can find beta version at
> https://sourceforge.net/project/showfiles.php?group_id=114970&package_id=124581&release_id=336416
> Please help me to make musmap free of bugs (reportings bugs, feature
> requests, ...).
> Musmap is a web mapping interface which has an advanced users/profiles
> management system.
> More information at http://musmap.sourceforge.net/
> Simple ChangeLog at http://musmap.sourceforge.net/todo/
> CVS changelog at
> http://musmap.sourceforge.net/cvschangelog/cvschangelogbuilder_musmap.html
> I will put a development version online in some weeks (the actual demo is
> outdated 0.8.1 version).
> Mathieu Parent
> Simple Changelog:
> New install procedure (easier)
> SVG output (in the print dialog)
> Real symbol management (not in the template map file) (RFE #1114571)
> Date display using client time zone if available
> Measure tool now draws polygons (SVG for Gecko and VML for IE)
> Read privileges are now effective: not readable objects are not loaded
> More complete musmap capabilities description in about.php
> OGR support for SQL and GetInformationSchema
> GetInformationSchema supported by Shapefiles, dbf, mysql, postgresql
> Explorer: Get all table info automaticaly (using GetInformationSchema)
> Model: adding connections (parent of data_sources)
> Complete rewrite of the model hierarchy API using collections
> Explorers: Allow child nodes batch deletion
> Import ESRI XML metadata for shapefiles (need PHP5 which has DOM
> extension)
> Zoom to layer
> Query results are lost if layer index changes (Bug #1123873)
> Ability to change parent node
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050620/141f7dc0/attachment.html
