antialias crash
Timothy Reed
tim.reed at BAESYSTEMS.COM
Mon Jun 20 14:19:00 EDT 2005
I am having an issue when I turn antialias'ing on in my map file. If I
am using a modified version of the mapserver demo I get an internal
server error, if I use a WMS client no image is returned. If I take out
the antialias everything works like a champ! Any ideas?
TIA,
Tim
./mapserv-4.6 -v
MapServer version 4.6.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
MAP
# Start of map file
NAME DEMO2
STATUS ON
SIZE 1000 500
EXTENT -179 -89 179 89
UNITS DD
SHAPEPATH "data"
IMAGECOLOR 0 0 153
DEBUG ON
PROJECTION
"ellps=GRS80"
"datum=WGS84"
"init=epsg:4326"
END
#OUTPUTFORMAT
# NAME jpeg
# DRIVER "GD/JPEG"
# # quality setting: 0 is minimum quality, 100 is maximum quality
# FORMATOPTION QUALITY=100
# # data format
# MIMETYPE "image/jpeg"
# # currently, there is no real grayscale jpeg output available
# IMAGEMODE RGB
# EXTENSION "jpg"
#END
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
# data format
MIMETYPE "image/png"
IMAGEMODE RGBA
EXTENSION "png"
END
# Start of symbol definitions (we're only using a few)
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
SYMBOL
NAME "cartoline"
TYPE cartoline
FILLED TRUE
LINECAP butt
LINEJOIN miter
LINEJOINMAXSIZE 1
# STYLE 10 5
END
# Start of web interface definition (including WMS enabling metadata)
WEB
HEADER demo_header.html
TEMPLATE demo2.html
FOOTER demo_footer.html
# MINSCALE 500000
IMAGEPATH "/usr/local/apache2/htdocs/tmp/"
IMAGEURL "/tmp/"
LOG "mapserver.log"
METADATA
WMS_TITLE "Mapserver Demo for Q2"
WMS_ONLINERESOURCE "http://boris:8080/cgi-bin/q2-mapserv?"
WMS_SRS "epsg:4326"
WMS_ABSTRACT "Testing MapServer capabilities for use within Q2"
END
END
LEGEND
KEYSIZE 18 12
IMAGECOLOR 211 211 211
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
QUERYMAP
SIZE 200 200
STATUS ON
STYLE HILITE
COLOR 255 0 0
END
# Start of reference map
REFERENCE
IMAGE data/land_shallow_topo_120.png
EXTENT -180 -90 180 90
SIZE 120 120
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
SCALEBAR
TRANSPARENT OFF
COLOR 0 0 0
OUTLINECOLOR 0 0 0
BACKGROUNDCOLOR 255 255 255
STATUS ON
POSITION LR
STYLE 1
END
# LAYER: Low-resolution Map of the World
LAYER
NAME full_world
GROUP background
STATUS OFF
MINSCALE 50000000
DATA "land_shallow_topo_full.png"
TYPE RASTER
METADATA
WMS_TITLE "World Backdrop"
WMS_SRS "EPSG:4326"
END
END
# LAYER: Medium-resolution Map of the World
LAYER
NAME medium_world
GROUP background
MAXSCALE 50000000
MINSCALE 5000000
STATUS OFF
TILEINDEX "tindex_06-17-05.shp"
TILEITEM "Location"
TYPE RASTER
METADATA
WMS_SRS "EPSG:4326"
END
END
# LAYER: HIGH-res Map of the World
LAYER
NAME small_world
GROUP background
MAXSCALE 5000000
MINSCALE 500000
STATUS OFF
TILEINDEX "world2.shp"
TILEITEM "Location"
TYPE RASTER
METADATA
WMS_SRS "EPSG:4326"
END
END
# LAYER: Filled in Polygon Map of the World
LAYER
NAME world_background
GROUP background
DATA "World_countries_shp"
TYPE POLYGON
STATUS OFF
MAXSCALE 500000
CLASS
NAME 'World Background'
COLOR 0 102 0
SIZE 7
END
METADATA
WMS_SRS "EPSG:4326"
END
END
# LAYER: 10 Grid Lines
LAYER
NAME grid3
GROUP gridlines
METADATA
DESCRIPTION "Grid"
END
TYPE LINE
STATUS ON
MINSCALE 100000000
CLASS
NAME "Grid"
COLOR 0 0 0
LABEL
COLOR 255 255 255
TYPE BITMAP
SIZE SMALL
POSITION AUTO
PARTIALS FALSE
BUFFER 5
END
END
PROJECTION
"init=epsg:4326"
END
GRID
LABELFORMAT DDMM
MINARCS 10
MININTERVAL 10
MINSUBDIVIDE 20
END
END
# LAYER: 4 Grid Lines
LAYER
NAME grid2
GROUP gridlines
METADATA
DESCRIPTION "Grid"
END
TYPE LINE
STATUS ON
MAXSCALE 100000000
MINSCALE 5000000
CLASS
NAME "Grid"
COLOR 0 0 0
LABEL
COLOR 255 255 255
TYPE BITMAP
SIZE SMALL
POSITION AUTO
PARTIALS FALSE
BUFFER 5
END
END
PROJECTION
"init=epsg:4326"
END
GRID
LABELFORMAT DDMM
MINARCS 4
MININTERVAL 4
MINSUBDIVIDE 4
END
END
# LAYER: 1 Grid Lines
LAYER
NAME grid1
GROUP gridlines
METADATA
DESCRIPTION "Grid"
END
TYPE LINE
STATUS ON
MAXSCALE 5000000
CLASS
NAME "Grid"
COLOR 0 0 0
LABEL
COLOR 255 255 255
TYPE BITMAP
SIZE SMALL
POSITION AUTO
PARTIALS FALSE
BUFFER 5
END
END
PROJECTION
"init=epsg:4326"
END
GRID
LABELFORMAT DDMM
MINARCS 1
MININTERVAL 1
MINSUBDIVIDE 1
END
END
# LAYER: Road Lines
LAYER
NAME roads_line
GROUP roads
TYPE LINE
DATA "the_geom from roads"
CONNECTION "user=reed dbname=Q2MAPS host=localhost port=5432"
CONNECTIONTYPE postgis
STATUS OFF
CLASSITEM "name"
CLASS
NAME 'Interstate Highway'
EXPRESSION /^Interstate/
MAXSCALE 19000000
STYLE
SYMBOL 'cartoline'
ANTIALIAS TRUE
COLOR 165 42 42
SIZE 4
END
STYLE
SYMBOL 'cartoline'
# ANTIALIAS TRUE
COLOR 255 165 0
SIZE 2
END
TEMPLATE "road.html"
END
CLASS
NAME 'US Route'
EXPRESSION /^US/
MAXSCALE 7500000
STYLE
SYMBOL 'cartoline'
# ANTIALIAS TRUE
COLOR 240 255 255
SIZE 2
END
END
CLASS
NAME 'State Route'
EXPRESSION /^State/
MAXSCALE 2500000
STYLE
SYMBOL 'cartoline'
# ANTIALIAS TRUE
COLOR 255 255 0
SIZE 1
END
END
CLASS
NAME 'ROADS'
MAXSCALE 1500000
STYLE
COLOR 0 0 0
SIZE 8
END
END
TOLERANCE 10
PROJECTION
"proj=latlong"
"ellps=GRS80"
"datum=WGS84"
END
HEADER "road_header.html"
FOOTER "cities_footer.html"
METADATA
WMS_TITLE "Roads"
WMS_SRS "EPSG:4326"
END
END
# LAYER: Road Symbols
LAYER
NAME roads_symbols
TYPE ANNOTATION
STATUS OFF
#Grab all Routes that do not have commas in the name
FILTER "name !~* ','"
LABELITEM "road_num"
CLASSITEM "name"
CLASS
NAME 'Interstate Symbol'
COLOR 255 255 255
OUTLINECOLOR 255 255 255
SYMBOL 'symbols/interstate.gif'
LABEL
MINFEATURESIZE AUTO
MINDISTANCE 150
POSITION CC
SIZE TINY
COLOR 255 255 255
END
END
CLASS
NAME 'US Route Symbol'
EXPRESSION /^US/
MAXSCALE 7500000
COLOR 0 0 0
OUTLINECOLOR 0 0 0
SYMBOL 'symbols/ushwy.gif'
LABEL
MINFEATURESIZE AUTO
MINDISTANCE 150
POSITION CC
SIZE TINY
COLOR 0 0 0
END
END
CLASS
NAME 'State Route Symbol'
EXPRESSION /^State/
MAXSCALE 1750000
COLOR 0 0 0
OUTLINECOLOR 0 0 0
SYMBOL 'symbols/sthwy.gif'
LABEL
MINFEATURESIZE AUTO
MINDISTANCE 150
POSITION CC
SIZE TINY
COLOR 0 0 0
END
END
END
# LAYER: Road Labels
LAYER
NAME roads_label
TYPE ANNOTATION
STATUS OFF
LABELMAXSCALE 1000000
LABELITEM "name"
CLASSITEM "name"
CLASS
COLOR 255 255 255
LABEL
COLOR 255 255 255
TYPE BITMAP
SIZE MEDIUM
POSITION AUTO
PARTIALS FALSE
BUFFER 2
END
END
METADATA
WMS_TITLE "Road Names"
END
END
# LAYER: City Labels
LAYER
NAME cities_label
TYPE ANNOTATION
DATA "the_geom from cities"
STATUS OFF
LABELITEM "name"
CLASSITEM "name"
CLASS
EXPRESSION ([pop_2000] > 250000 )
COLOR 255 255 255
LABEL
COLOR 255 255 255
# BACKGROUNDCOLOR 211 211 211
# BACKGROUNDSHADOWCOLOR 211 211 211
# BACKGROUNDSHADOWSIZE 2 2
# ANTIALIAS TRUE
TYPE BITMAP
SIZE MEDIUM
POSITION AUTO
PARTIALS FALSE
BUFFER 2
END
END
CLASS
EXPRESSION ([pop_2000] > 30000 )
MAXSCALE 8000000
COLOR 255 255 255
LABEL
COLOR 255 255 255
TYPE BITMAP
SIZE MEDIUM
POSITION AUTO
PARTIALS FALSE
BUFFER 2
END
END
CLASS
MAXSCALE 2000000
EXPRESSION ([pop_2000] > 10000 )
COLOR 255 255 255
LABEL
COLOR 255 255 255
TYPE BITMAP
SIZE MEDIUM
POSITION AUTO
PARTIALS FALSE
BUFFER 2
END
END
CLASS
MAXSCALE 600000
EXPRESSION ([pop_2000] > 1000 )
COLOR 255 255 255
LABEL
COLOR 255 255 255
TYPE BITMAP
SIZE MEDIUM
POSITION AUTO
PARTIALS FALSE
BUFFER 2
END
END
METADATA
WMS_TITLE "City Names"
END
END
# LAYER: Cities
LAYER
NAME cities
TYPE POINT
STATUS OFF
CLASSITEM "name"
CLASS
SYMBOL 'circle'
NAME 'CITIES'
SIZE 3
COLOR 204 255 0
TEMPLATE "cities.html"
EXPRESSION ([pop_2000] > 250000)
END
CLASS
MAXSCALE 8000000
SYMBOL 'circle'
SIZE 3
COLOR 204 255 0
EXPRESSION ([pop_2000] > 30000)
END
CLASS
MAXSCALE 2000000
SYMBOL 'circle'
SIZE 3
COLOR 204 255 0
EXPRESSION ([pop_2000] > 10000)
END
CLASS
MAXSCALE 600000
SYMBOL 'circle'
SIZE 3
COLOR 204 255 0
END
TOLERANCE 10
PROJECTION
"proj=latlong"
"ellps=GRS80"
"datum=WGS84"
END
HEADER "cities_header.html"
DUMP TRUE # allow GML export
METADATA
WMS_TITLE "Cities"
WMS_SRS "EPSG:4326"
END
END
# LAYER: City Query
LAYER
NAME cities_query
GROUP cities
TYPE QUERY
STATUS OFF
CLASS
SYMBOL 'circle'
SIZE 3
COLOR 204 255 0
END
TOLERANCE 10
PROJECTION
"proj=latlong"
"ellps=GRS80"
"datum=WGS84"
END
METADATA
WMS_TITLE "Cities Query"
WMS_SRS "EPSG:4326"
END
END
# LAYER: State outline
LAYER
NAME states
TYPE LINE
DATA statesp020
STATUS ON
CLASS
NAME 'STATES'
COLOR 102 51 255
SIZE 7
END
PROJECTION
"proj=latlong"
"ellps=GRS80"
"datum=WGS84"
END
METADATA
WMS_TITLE "State lines"
WMS_SRS "EPSG:4326"
END
END
# LAYER: World Countries outline
LAYER
NAME WorldGen_Outline
TYPE LINE
STATUS ON
CLASS
NAME 'WorldGen_Outline'
COLOR 255 0 0
SIZE 7
END
METADATA
WMS_TITLE "World Countries"
WMS_SRS "EPSG:4326"
END
END
EN
Timothy Reed
Software Engineer
BAE Systems - National Security Solutions
428 Phoenix Drive
Griffiss Business & Technology Park
Rome, NY 13441
Phone: (315)838-2284
Email: tim.reed at baesystems.com
"I reject your reality, and substitute my own" - Adam Savage
