How to set Projection in MAP file?
Dennis Megarry dennis at MEGARRY.COM
Tue Jun 21 08:43:53 EDT 2005
I have been trying to do weather overlays using GIF images over GeoTIFFs.  The GIF images are a different projection:
Projection: Geographic Lat/Lon
Datum: WGS84
Planar Units: Arc Degrees
How do I set this up in the MAP file under the projection tag just for the GIF images?
I've also setup a index shp file, would it be better to use that? (although again I don't know how to set this up either).
Dennis
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20050621/87854605/attachment.html
