Queries
Peter Kingsbury
peterkingsbury at ISTOP.COM
Thu Jun 23 23:37:22 EDT 2005
Hello Pericles and List,
I have gone over the provided attachments... they are certainly helpful.
Many thanks!
One problem I am having, is that Chameleon does not seem to take into
account the HEADER/FOOTER/TEMPLATE fields I place in the mapfile
layers... it simply takes from the QueryResults.phtml file that comes
with the server.
I've confirmed that the placement of the HEADER/FOOTER/TEMPLATE fields
-do- help, as without them, I get empty query results each time.
Each time that the query results appear with the QueryResults.phtml file
as a template, I get a table with the complete data set, which is good,
but a little too much information for my purposes! The mapfile seems to
ignore my custom .html templates.
Any ideas?
The search continues,
- Peter
Pericles S. Nacionales wrote:
> Peter,
> Check http://terrasip.gis.umn.edu/projects/tutorial/section3.html and
> look at the map and template files for each example. I'm currently in
> the process of updating the tutorial and it will make more sense when
> I'm done... perhaps in the next two weeks.
> Anyway, to setup a non-spatial query in MapServer (generating maps is
> a form of query too!) you need to define a query template in each
> layer to be queried. In addition, you might also want to define a
> header and footer for each of the layer. Attached you will find the
> relevant template files and a mapfile. Open the mapfile and have a
> look at the layer named cities_poly and also the web object--that's
> where all the query-related parameters are defined.
> As for the interface, I don't know about Chameleon but in the
> MapServer CGI world you invoke queries by changing the mode to query
> or nquery. I suspect it would be the same thing with PHP/MapScript.
> Good luck!
> -Perry
> Peter Kingsbury wrote:
>> Hello list,
>> I have been reading through various documentation for some time, on
>> how to
>> accomplish simple queries with the data set I have, on the Chameleon
>> site I
>> have in place.
>> At this point, I am not sure which of the sites, documents, or
>> manuals will
>> lead me to my goal; may I request a pointer to a useful document
>> which will
>> describe how to setup the initial environment to enable querying?
>> I apologize if this is vague, however I am just beginning to scratch the
>> surface, hence I am reading as much as I can on the subject!
>> Much thanks,
>> - Peter
