buffer (GEOS) in Mapserver 4.6
Lowell Filak
lfilak at MEDINACO.ORG
Fri Jun 24 13:36:53 EDT 2005
The following message was sent by Monica Socol <Monica.Socol at DPRA.COM>
on Fri, 24 Jun 2005 12:24:20 -0500.
> Thank you for your response, Lowell.
> I am working with PHP Mapscript. Do you know if the ShapeObj from PHP
> Mapscript exposes the same functionality as swigmapscript? I didn't find
> anything in the objects documentation about it.
> Monica
> -----Original Message-----
> From: Lowell Filak [mailto:lfilak at medinaco.org]
> Sent: June 24, 2005 1:16 PM
> To: Monica Socol; MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] buffer (GEOS) in Mapserver 4.6
> on Wed, 22 Jun 2005 15:48:00 -0500.
> > I have found in the History document for Mapserver version 4.6:
> > "Finished code to convert back and forth between GEOS geometries.
> Buffer
> > and
> > convex hull operations are exposed in mapscript"
> > But this is all I could find. Does this mean that mapscript exposes
> > Buffer functionality for different types of geometries (not only
> point)?
> > Does anyone knows how to use GEOS with mapscript?
Monica,
Sorry, I'm not sure...
Lowell
